nsx calipers type r suspension
I know this topic has been talked about before, but I was unable to find any info after searching. My question is what modification will I have to do to fit nsx calipers on my type R. Will I have to switch the rotors, brake lines? I also know that legend gs's calipers is a better choice, but I already have the nsx calipers and all I need is the is some info before I start this brake upgrade. Any info will be greatly appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXcellent »</TD></TR><TR><TD CLASS="quote">This was just posted last week.
Just change out brake rotors and calipers. Done deal. </TD></TR></TABLE>
Thanx thats all I needed to know!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lseg4door »</TD></TR><TR><TD CLASS="quote">no doesn;t work</TD></TR></TABLE>
What do you mean?
What do you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crisparra »</TD></TR><TR><TD CLASS="quote">
I know this topic has been talked about before, but I was unable to find any info after searching. </TD></TR></TABLE>
j00're either:
-full of chit
or
-can't use the search function
come on, this is one of the most popular subjects in the ITR forum....slightly behind the oil discussion...
j00're either:
-full of chit
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo »</TD></TR><TR><TD CLASS="quote">
raight... and j00 cant j00se the NSX r0t0rs either. Stock ITR r0t0rz, NSX klappers, ITR caliper carriers. Pads are the same. And search, goddammit....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
raight... and j00 cant j00se the NSX r0t0rs either. Stock ITR r0t0rz, NSX klappers, ITR caliper carriers. Pads are the same. And search, goddammit.... </TD></TR></TABLE>
you can use rear nsx rotors in the rear if you use rear nsx calipers with custom brackets.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xdriver »</TD></TR><TR><TD CLASS="quote">
Well you can use any caliper/5x114 rotor you want in front or rear with custom brackets *shrug*
RJ - who's got something brewing for the fronts...
</TD></TR></TABLE>Well you can use any caliper/5x114 rotor you want in front or rear with custom brackets *shrug*
RJ - who's got something brewing for the fronts... </TD></TR></TABLE>
Gonna cut holes in the floor now and stop it like Fred Flintstone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg »</TD></TR><TR><TD CLASS="quote">Gonna cut holes in the floor now and stop it like Fred Flintstone?</TD></TR></TABLE>
Not quite
Something 4-piston, and much cheaper than the smurf blue ****.
Not quite
Not quite
Something 4-piston, and much cheaper than the smurf blue ****.</TD></TR></TABLE>
I know! I know! :raises hand:
Not quite
