95 del sol si missing, cant figure out?
Old Oct 26, 2004 | 06:37 PM
aemciv's Avatar
Default 95 del sol si misfiring, cant figure out?
this morning it was fine. then at 6 I was leaving for school and it starts missing at idle. the whole "dut dut dut dut dut" and increases when I give it some gas. I replaced the plugs and wires and still nothing. What do you guys think?
I hope its not a cracked valve or something
any other idea?
prose
Modified by aemciv at 3:53 AM 10/27/2004
Old Oct 26, 2004 | 06:56 PM
aemciv's Avatar
the plugs were not brand new but in good condition
prose
Old Oct 26, 2004 | 07:09 PM
Targa250R's Avatar
be professional
Default Re: 95 del sol si misfiring, cant figure out? (aemciv)
Has it thrown a CEL?
When was the last time you had your distributor cap and rotor replaced?
Old Oct 26, 2004 | 07:10 PM
aemciv's Avatar
Default Re: (aemciv)
its almost like the timing is off. what are the chances of the timing belt slipping a tooth?
btw. the engine is stock
prose
Old Oct 26, 2004 | 07:11 PM
aemciv's Avatar
Default Re: 95 del sol si misfiring, cant figure out? (Targa250R)
I just got the car so to my knowledge the the cap and rotor have never been changed.
prose
Old Oct 26, 2004 | 07:27 PM
one slow eg5's Avatar
DOUBLE CHECK DISTRIB...
Old Oct 26, 2004 | 07:31 PM
aemciv's Avatar
Default Re: 95 del sol si misfiring, cant figure out? (one slow eg2)
bad news. i pulled each wire and the #2 cylinder did not drop idle when i pulled it and it is sparking on the valve cover. so no compression in that cylinder im guessing? valve?
prose
Old Oct 26, 2004 | 07:53 PM
2fast4u831's Avatar
I'm really 2slow
or rings
Old Oct 27, 2004 | 04:43 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemciv &raquo;</TD></TR><TR><TD CLASS="quote">bad news. i pulled each wire and the #2 cylinder did not drop idle when i pulled it and it is sparking on the valve cover. so no compression in that cylinder im guessing? valve?
prose</TD></TR></TABLE>
Bad/clogged injector possibly?
Do a compression test.
Old Oct 27, 2004 | 11:14 PM
RICE POLICE SIP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
Do a compression test.</TD></TR></TABLE> yeah if you're getting spark still but nothing is happening then check the injector connection and what not...
Old Oct 28, 2004 | 03:42 AM
Average Al's Avatar
check if u got the firing order right
fuel filter??
bad o2??
jsut do a basic tune up
Dabears
Jul 4, 2016 06:48 AM
del solares
Jan 12, 2013 06:46 PM
doobie60
Apr 24, 2011 07:14 AM
wolf95
20
Nov 6, 2010 04:34 AM
toben
14
Jan 31, 2007 12:13 PM
