FS- GE 84.5mm GSR block, Portflow/Endyn Head, Full Race Rods, Endyn pistons/ITR oil pump and TONS MO
Old Oct 26, 2004 | 05:36 PM
Bnjmn's Avatar
Default FS- GE 84.5mm GSR block, Portflow/Endyn Head, Full Race Rods, Endyn pistons/ITR oil pump and TONS MO
DOHC Vtec Head (B16)
- Portflow port/polish ($900)
- new ITR outer springs, Portflow inners
- EF1 titanium retainers
- chambers enlarged to 84.5mm and quench areas machined by Endyn
- NEW valve seals
- stainless exhaust valves
- ITR lost motion devices
- $1000 shipped SOLD
I'm parting out the bottom end of my built B18C block. The engine has been idled for about 20 minutes. That is the extent of the wear on all the items listed. That means the block has essentially new bearings, new crank seals and new main bolts.
Prices are as follows:
GE sleeved GSR block (84.5mm)- comes with mains, new main bolts, main bearings, girdle, oil cooler, hard pipe, thermostat and housing, new front crank seal, timing belt cover, alternator bracket and driver's side upper mount bracket. Also comes with a micropolished GSR crank with matched bearings that give the ideal bearing/crank clearance of 0015".
The engine was sleeved by GE with their newer process so you don't need to worry about sleeve sinkage. In addition, the block was line honed and the sleeves honed ($300) by Endyn and had the internal oil passages ported by Endyn. $1100 shipped. Or take the pistons too- $1400 shipped for the package. SOLD
Full Race GSR Rods-
Again, these rods have been idled for 20 minutes.
$450 shipped SOLD
Wiseco/Endyn 84.5mm FI Pistons-
These have been coated by Swaintech- PC9 on the skirts and Gold Coat on the tops.
$160 in coatings. Compression ratio ranges from 9.5-9:8 depending on the head used (ITR/GSR). All info on compression ratios can be found @ http://www.theoldone.com
Come with rings that have been idled for 20 minutes.
$375 SOLD
tensioner- $20 shipped
GSR oil pickup/windage tray- $50 shipped
GSR fuel rail with pressure regulator- complete with hose, ready to bolt on- $60 shipped
GSR main bearings- 2 brown, 1 green- new- $10 shipped
35mm Tial WG elbow- 35mm flange on one end, 40mm flange on the other end- $20 shipped
OBD-1 B series alternator- great condition- $80 shipped
Angel Eye projector headlights with no front plastic lens cover- $35 shipped
GSR IACV- $18 shipped
B series Coolant Temp Sensor (1)- $12 shipped
GSR engine/tranny stiffeners- $15 shipped
'91 CRX grey roof panel- very very good condition- $45 shipped
'88 Acura clutch install tool (works with variety of Honda/Acuras)- $5 shipped
Civic-Momo steering wheel adapter/spacer- It should with with any Honda/Acura- allows moutning a Sparco/Momo/etc. wheel with the 6 hole pattern- $25 shipped
92-95 Civic, 94-01 Integra sound deadening material- heavy vinyl to be placed under carpet- ideal for competition car audio installs. $80 shipped (heavy!)
'93 Acura driveshaft- $20 shipped (I'll email a pic- I don't know if it is left or right)
(2) B series Vtec distributor bodies (the metal part- you can swap in LS innards)-
$25 shipped
LS Distributor body- leg chopped off so it can be mounted on Vtec head- $12 shipped
(3) coils/ignitors from inside a B series distributor- if you have a bad distributor, this should fix it- $12 shipped each
Viper 1100.5 amp- only used for display purposes- $250 shipped
(2) Adire Audio Shiva (mark 4) 12" sub- $80 shipped each
2001 GSR cluster modded to fit very very well into EG dash. $125 shipped
Black 92-95 Civic Hatch Dash. Good condition. Make offer
All interior parts from a '92 Civic CX with black interior. Make offer. I have all the plastic parts, rear seats,
Also- anything not involved in rolling or steering off a '92 Civic HB- this includes lights, mirrors, etc.
Civic Roller for sale- '92 Civic, 118K miles, Very little rust underneath, needs paint/some body work. $200 and must pick up in Rochester, NY
I have pics of EVERYTHING. PM me with your email address and I'll be happy to send pics of whatever you need.
Email is best- blesnak@weitzlux.com
Email for pics.
Thanks
Ben
Modified by Bnjmn at 5:00 PM 11/3/2004
Modified by Bnjmn at 10:02 AM 11/4/2004
Modified by Bnjmn at 9:04 PM 12/2/2004
Modified by Bnjmn at 1:28 PM 12/7/2004
Modified by Bnjmn at 11:40 AM 12/9/2004
Modified by Bnjmn at 8:05 PM 12/13/2004
Modified by Bnjmn at 7:11 PM 12/16/2004
Old Nov 2, 2004 | 04:38 AM
Bnjmn's Avatar
Default Re: FS- GE 84.5mm GSR block, Portflow/Endyn Head, Full Race Rods, Endyn pistons/ITR oil pump and TON
up....
Old Nov 5, 2004 | 09:32 AM
turbo*s2k's Avatar
I replied on your other post. Interested in the head.
Old Nov 11, 2004 | 08:47 AM
Bnjmn's Avatar
up...make offers...somebody needs this stuff
Old Nov 22, 2004 | 03:28 PM
Bnjmn's Avatar
up.......
Old Nov 28, 2004 | 01:06 AM
clarkekent13's Avatar
pmed
Old Nov 30, 2004 | 04:57 PM
_SHEP_'s Avatar
i would love to buy both block and head. i just got to get rid of my car... I'll let you know soon
Old Dec 2, 2004 | 05:01 PM
Bnjmn's Avatar
Default Re: (BOOSTEDebp)
up.....make offers on anything.
also have tons of black interior parts from a '92 Hatch for sale. Make offers.
Old Dec 8, 2004 | 11:47 PM
roadrunner's Avatar
Default Re: (Bnjmn)
block still available? ...from what year is the block (looking for obd2, for when I have to smog it) and would you do a package of block/crank, pistons, and con rods? What else would I need, other than timing belts, gaskets, etc, to get this running?
thanx...
Old Dec 9, 2004 | 07:53 AM
ScottEK's Avatar
Default Re: (roadrunner)
Ben is a great guy to do business with, he sold me a Helms for $15 and shipped it out extremely fast
Hope I can save up fast enough to buy those rods off you!
Old Dec 13, 2004 | 04:06 PM
Bnjmn's Avatar
Default Re: (beta13)
up
bon3z1201
Sep 27, 2006 09:54 PM
Bnjmn
Dec 19, 2004 04:57 PM
Bnjmn
Jul 17, 2004 11:50 AM
