what obd1 d-series distributer fits a sohc zc (obdo)
Old Oct 26, 2004 | 04:53 PM
yoursupinehead's Avatar
Default what obd1 d-series distributer fits a sohc zc (obdo)
anyone know?
i want to forward date my motor to hondata it.
Old Oct 26, 2004 | 05:00 PM
smart monkey's Avatar
Default Re: what obd1 d-series distributer fits a sohc zc (yoursupinehead)
I think the 92-95 civic dx will work
Old Oct 26, 2004 | 07:01 PM
Default Re: what obd1 d-series distributer fits a sohc zc (smart monkey)
tried that one already (it's the only one i tried, only one available to me) thanks tho, any other thoughts?
Old Oct 26, 2004 | 07:15 PM
krazie1's Avatar
BANNED
just make sure u connect the wires as many have this problem
I thought I did but luckily before anything check both manuals
here is something to make the install easier:
all wires go color to color and the ticker white wire connectes to the yellow/green striped wire for power
and it should fire right up unless u get one with the internal wire to the dizzy plug crossed someone brought me one like this and made the swap a nightmare
Old Oct 26, 2004 | 07:24 PM
Default Re: what obd1 d-series distributer fits a sohc zc (krazie1)
the plugs aren't the problem, the 3 dizzy mounting points don't come anywhere near lining up
Old Oct 26, 2004 | 07:39 PM
that is weird I thought it would work. reason is my friend has a sohc zc he put in his 88-91 si and he used the stock si dist. to me the 92-95 dx looks like it uses the same head pattern for the dist. I guess I was wrong.
Old Oct 26, 2004 | 10:25 PM
Nerologic's Avatar
did u try b series distro's? liek a ls one and a gsr/b16 one?? im pretty sure one of those would almost line up...
Old Oct 27, 2004 | 03:52 AM
Default Re: (Nerologic)
worth a shot
Old Oct 27, 2004 | 06:07 AM
crx_88_si's Avatar
are obd-2a distro's ELECTRONICALLY the same as obd-1? if so, try a y7 or y8 dist. should bolt right onto a d16a6 but use obd-1 electronics.
Old Oct 27, 2004 | 07:17 AM
crxgator's Avatar
Default Re: (crx_88_si)
try the y8 one, thats what ill be doing hopefully...should be making a plug-n-play distributor wiring harness soon...
Old Oct 27, 2004 | 09:32 AM
Default Re: (crxgator)
thanks, a guy i work with may have one.
you like converge?
tjscivic
Aug 28, 2009 10:18 AM
arc_55
Jul 1, 2006 09:40 AM
arc_55
Jun 30, 2006 12:36 PM
1990civicsiguye
Aug 18, 2003 10:37 AM
KevronsEG
Jan 21, 2003 12:17 PM
