recommended power steering fluid?
Old Oct 26, 2004 | 12:58 PM
autoground's Avatar
Default recommended power steering fluid?
for a 97 integra ls, thanks
Old Oct 26, 2004 | 01:11 PM
virusiidx's Avatar
honda geniune ps fluid
Old Oct 26, 2004 | 01:25 PM
autoground's Avatar
Default Re: (virusiidx)
awsome! im i able to get this ps fluid at autozone or kragen? thanks again
Old Oct 26, 2004 | 01:26 PM
timmy8151's Avatar
Default Re: (autoground)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoground &raquo;</TD></TR><TR><TD CLASS="quote">awsome! im i able to get this ps fluid at autozone or kragen? thanks again </TD></TR></TABLE>
You can't get genuine honda ps fluid at those stores. However you can get a "honda" type ps fluid. I've used honda type ps fluid in my car without any problems.
Old Oct 26, 2004 | 01:29 PM
orangebarius's Avatar
Default Re: (timmy8151)
i used the honda one i found at strauss and it works good. its made for hondas it says.
Old Oct 26, 2004 | 01:31 PM
Padawan's Avatar
Darth ModerVader
Default Re: recommended power steering fluid? (autoground)
Yes, either get genuine fluid from a Honda or Acura dealer, or make sure that the fluid you buy at an auto parts store is specifically labeled "For use in Honda & Acura PS systems".
Old Oct 26, 2004 | 01:38 PM
sabotage7's Avatar
Default Re: recommended power steering fluid? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Yes, either get genuine fluid from a Honda or Acura dealer, or make sure that the fluid you buy at an auto parts store is specifically labeled "For use in Honda & Acura PS systems". </TD></TR></TABLE>
Old Oct 26, 2004 | 01:43 PM
autoground's Avatar
great! i figure its time to change the fluid, been 3 years
Old Oct 26, 2004 | 03:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
change the PS fluid? I've never done that, how is it done?
Old Oct 26, 2004 | 03:10 PM
rovigian's Avatar
Default Re: recommended power steering fluid? (PatrickGSR94)
You basically disconnect the bottom hose to the reservoir and put the hose into a water bottle.
You then start the car 2-5 times and rev it up to 3k rpms and it pumps all of the fluid out.
Then you just reconnect the hose and refill the reservoir.
Takes 10 minutes max.
Old Oct 26, 2004 | 03:11 PM
virusiidx's Avatar
vacuum???
Old Oct 26, 2004 | 03:13 PM
Community Builder
Default Re: recommended power steering fluid? (rovigian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">You basically disconnect the bottom hose to the reservoir and put the hose into a water bottle.
Takes 10 minutes max.</TD></TR></TABLE>
Is that procedure shown in the Helms manual? Hell I've never even seen it listed on the maintenance schedule. I know my PS is the same it's been since I bought the car 3.5 yrs and 90K miles ago, no problems.
Old Oct 26, 2004 | 03:30 PM
rovigian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Is that procedure shown in the Helms manual? Hell I've never even seen it listed on the maintenance schedule. I know my PS is the same it's been since I bought the car 3.5 yrs and 90K miles ago, no problems.</TD></TR></TABLE>
It is in the Haynes. I just did mine because power steering fluid is cheap and it wouldn't hurt.
Oh by the way, is is simple to do if you have one person hold the bottle while the other runs the car.
timmy8151's Avatar
An easier and less messy way of changing the PS fluid is using the turkey baster method. Just suck out the old fluid with a turkey baster and add new fluid. Continue doing this method until the fluid comes out clean. The only thing is that it's hard to fully change the fluid using this method.
W95civicEXcoupe
17
Apr 14, 2015 06:11 AM
h4mza
Sep 6, 2014 06:03 PM
jvue
May 21, 2010 12:17 PM
kupras
Dec 12, 2005 08:07 PM
Silvteg95
Jul 30, 2005 08:54 PM
