Help!! oil and smoke from turbo downpipe
Old Oct 26, 2004 | 11:47 AM
rideblitz's Avatar
Default Help!! oil and smoke from turbo downpipe
help me please. I just installed a brandnew t3 turbo on my crx, at a shop. I'm still there now. Once we got everything situated we started the car and oil and smoke came flying out the downpipe from the turbo. The turbo is new, why would this be happening? please help!
Old Oct 26, 2004 | 11:58 AM
Chris F's Avatar
Default Re: Help!! oil and smoke from turbo downpipe (rideblitz)
Do you really want an answer from us?
How is your turbo oil return line routed? If it's fine then your seals are shot.
-Chris
Old Oct 26, 2004 | 12:23 PM
slowpokesi's Avatar
Default Re: Help!! oil and smoke from turbo downpipe (ccfries)
did you prime the turbo first?
Old Oct 26, 2004 | 12:41 PM
mattssi's Avatar
possibly bad placement of your oil return, if not, you got a bunk turbo. Unless you have oil entering the turbo from the engine. like bad valve seals or worn piston rings.
Old Oct 27, 2004 | 07:43 AM
rideblitz's Avatar
Default Re: (mattssi)
Sorry, I can only post 5 times a day. I'm almost positive the seals are good, and we replaced the oil return just incase it was causing problems. But what we were wondering is if it would be possible for there to be to much oil getting pumped so fast into the turbo that the return can't get it all out quick enough. Could this be? And would regulating the oil feed flow help out if so? Thanks.
Old Nov 15, 2004 | 10:42 PM
PanikAttack's Avatar
Default Re: (rideblitz)
Did you ever figure out what this was? Im experiencing a similar problem.
I smell fuel and oil and the wastegate pipe is smoking up the cabin of the car
when i drive.
Old Nov 16, 2004 | 01:19 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (PanikAttack)
what size oil feed line are you using? i've been reading lately that if you use anything bigger then a -3AN it'll blow the oil seal due to the volume of oil flowing through.
Old Nov 16, 2004 | 03:55 AM
swlabhot's Avatar
1) Make sure your oil return is large enough
2) Make sure the there is sufficient vertical slope for the gravity drain from the turbo to the fitting on your oil pan.
Assuming that your turbo oil seals survived, this should fix it.
b20beast83
Apr 2, 2009 07:36 PM
sonne_side
Mar 31, 2009 11:40 PM
rideblitz
14
Oct 27, 2004 01:09 PM
alfee
Jul 29, 2004 01:44 PM
