Advantages : DPFI to MPFI?
Old Oct 26, 2004 | 08:23 AM
shivern's Avatar
Default Advantages : DPFI to MPFI?
Right now i have a 1990 DX with dual port fuel injection, what are the advantages of converting to Multi-port fuel injection? Im asking this because i can do it for some pretty cheap prices today.
Thanks!
Old Oct 26, 2004 | 08:29 AM
crx_88_si's Avatar
you get better control over your a/f.
Old Oct 26, 2004 | 09:03 AM
shivern's Avatar
Default Re: (crx_88_si)
Should I just use the ECU out of a Si or is there a better one?
Old Oct 26, 2004 | 09:33 AM
FalkenSiR's Avatar
Default Re: (shivern)
I've heard most people use the Si one. I'm not sure tho if you can use others...
Old Oct 26, 2004 | 10:12 AM
Mugen Dom's Avatar
Default Re: (fast88std)
only other one u can use is the integra one but makes u run pretty rich....and u can search this topic its been covered here SOOOOO many times.....but it is the best mod u can do for the cost its well worth it
Old Oct 26, 2004 | 10:28 AM
92integra_gs's Avatar
you will get more hp cuz you got more fuel to burn in the combustion chamber....
Old Oct 26, 2004 | 10:38 AM
julio_bOostamante's Avatar
I'm a Jackass
Default Re: (92integra_gs)
im thinking the same...i want to slao in my ZC cam in the 1.5 and go dpfi to mpfi ..that would be a nice upgrade ..right>
Old Oct 26, 2004 | 11:11 AM
Default Re: (julio_bOostamante)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julio_bOostamante &raquo;</TD></TR><TR><TD CLASS="quote">im thinking the same...i want to slao in my ZC cam in the 1.5 and go dpfi to mpfi ..that would be a nice upgrade ..right&gt;</TD></TR></TABLE>
definitely ... and it would be a start towards future projects like mini-me and swaps...
Old Oct 28, 2004 | 11:18 AM
I'm a Jackass
hmmm.....i think ill do that b4 the end of 2004....
i have the parts, just need the time and the timing belt...would i run the 1.5 belt or the 1.6 belt if a ran the cam alone with the 1.5 head. Or shoul o just swap the head with the ZC and be done with that. i wouls have to use the 1.6 belt along with the 1.6 water pump right? or are both 1.5 and 1.6 pumps the same? are the belts different in the amount of teeth they have?
Old Oct 28, 2004 | 12:53 PM
91tegrals's Avatar
the biggest diff is that the dpfi just dumps fuel in and it just pours in to cylinders mpfi uses the crank sygnal to know wat cyl get fuel and at wat time,,and you can use the pm6 ecu or a pg7 the pg7 will give you more fuel and slightly better performance..
harmonator84
Jan 14, 2007 10:32 AM
BlakeJ53
11
Dec 24, 2006 07:13 AM
ivanson
Mar 8, 2005 09:55 PM
terminaloverlowd
Oct 3, 2004 08:34 PM
pinoyboy204
Jul 26, 2003 04:11 AM
