Opinnions on 5W20
Old Dec 19, 2001 | 09:22 PM
paul_573's Avatar
Default Opinnions on 5W20
Any of you have any opinnions on the new 5W20 oil that Honda wants us to use in the new cars. I know that Ford began to use it as well. In my opinnion its a little too thin. I don't want to have to rebuild the motor after 5yrs. What do you all think. Should I switch to 5W30? Any opinnions???? The car is driven by my mom so it never sees more than 3000rpm- that is unless I drive it.
Old Dec 19, 2001 | 10:59 PM
Gasoline Fumes's Avatar
Default Re: Opinnions on 5W20 (paul_573)
I would use 10w-30. I think Honda uses 5w-20 for slightly better gas mileage.
Old Dec 20, 2001 | 12:16 PM
Perfectionist's Avatar
Do you want to keep your factory warranty? Use 5W-20. If not, use whatever you like. Apparently Honda is saying anything more than 5W-20 is too viscuous to flow properly into the areas with tight tollerances. Maybe, but I don't want to risk a burned crank bearing to prove them wrong. FWIW, I've been using the recomended 5W-30 in my '90 Civic Si since day one. I now have over 239,000 miles on it with no oil consumption or other engine issues to complain about.
Old Dec 20, 2001 | 12:36 PM
non-VTEC's Avatar
i think honda wants you to use 5W20 because you cant buy it in any other store other than maybe the honda parts department at your local dealer..........last time i went to the local auto parts store they had every grade imaginable except for 5W20.
b18cEggie
Transmission & Drivetrain
11
Dec 1, 2011 05:44 AM
hannslebo
May 26, 2009 05:38 PM
B18C-VTI_R
Aug 19, 2004 12:49 PM
Rocket
Jul 8, 2004 02:09 PM
