[Searched] Shaking wheel when braking..new rotors..
Old Oct 26, 2004 | 05:57 AM
hawaiidsm's Avatar
Default [Searched] Shaking steering wheel when braking..new rotors..
Okay, i've searched, and the situations in the archived threads are different from mine...
i have a '91 A/T Civic LX 4dr..63k on the clock
NEW pads and NEW rotors...
i've run two different sets of rims (Stocks 13"s and '95 GSRs 15"s) so i doubt it's a balancing issue
the whole steering rack was replaced as well
i've gotten a few suggestions so far... alignment, transmission, mounts (but they were checked)
here's the interesting part... when my pads and rotors were going to ****, the steering wheel would shake A LOT less or not at all
interesting part part II... when it downshifts on it's own (remember it's AT) from 2nd to 1st (i think) the rattling stops... so i'm thinking it's only in second (or third) gear that it rattles...
i'm just hoping that one day it doesn't suddenly stop and my steering wheel or something comes off and i go flying off the road... that would be no good.
Old Oct 26, 2004 | 06:06 AM
Bandit74's Avatar
What about the calipers?
Old Oct 26, 2004 | 06:17 AM
crx_88_si's Avatar
check your bushings... possible deflections due to forward loads ?
Old Oct 26, 2004 | 07:34 AM
tilt's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (hawaiidsm)
Pop the tranny into neutral then brake. see if it still shakes.
Also, check your wheel bearings for play.
Old Oct 26, 2004 | 01:38 PM
hawaiidsm's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (tilt)
yeah i've done the neutral thing, and it does still shake...
thanks guys, i'll check through the car this weekend
Old Oct 26, 2004 | 02:01 PM
Keith P's Avatar
Can is it a hard wobble or a vibration shake? try driving with a passenger and see if BOTH sides are visually shaking.. maybe we can eliminate one side ro the other as the problem
Old Oct 26, 2004 | 02:05 PM
JapJunkie's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (Keith P)
Wheel Bearings maybe.
Old Oct 26, 2004 | 02:11 PM
cvc323's Avatar
I had a similar problem. I replaced the old rotors but when I put the new rotors on I had the same problem. I had the new rotors cut or resurfaced, which is what I heard you are supposed to do with new rotors anyways, because they might have been damaged during shipping or whatever. Then the problem went away.
Old Oct 26, 2004 | 03:00 PM
efvader's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (cvc323)
I had this same problem too and I repalced front rotors twice...
I changed the rear drums and shoes and then it started to do it so i replaced the front rotors again thinking i warped them already.
Turned out that my drums that i bought brand new turned out to be warped.
Anyway check those.
deftones0817's Avatar
wheel bearing probably or a caliber is sticking...but i doub the caliber thing. Did you check to make sure the crown nut on the axles are tight? That sorta sounds like the crown nuts came loose so the axles has a little play in it. Check it out.
DEF
Old Oct 26, 2004 | 03:06 PM
CRXRTYPE's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (deftones0817)
u probably warped the rotors on first application, wouldn't be the first time
Old Oct 26, 2004 | 09:36 PM
MestizoRacer310's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (CRXRTYPE)
I'm also thinking warped rotors......did you torque down (in star pattern) to 80ft/lbs? or just cranked down w/ an impact wrench?
Also the bearings could be bad too...rotors could also have excessive lateral runout...
Old Oct 26, 2004 | 09:44 PM
Dyn0speed's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (MestizoRacer310)
*** tats crazy. u downshift from 2nd to 1st!
check axles and the 32mm bolt locking bolt
Old Oct 26, 2004 | 11:51 PM
hawaiidsm's Avatar
Default Re: [Searched] Shaking steering wheel when braking..new rotors.. (Dyn0speed)
thanks for the help guys, it'll be checked this weekend..
"*** tats crazy. u downshift from 2nd to 1st!"
lol no i meant when the auto trans does it on it's own, it's an old car so the downshifting is obvious... i hope i didn't come off like a TOTAL moron in this post.. maybe it's 3rd to 2nd? i have no ******' clue
Old Nov 23, 2004 | 01:46 AM
A_RU_BA's Avatar
hi grant!
raydavid1296
Suspension & Brakes
12
Nov 5, 2017 03:49 PM
skn181
Jul 1, 2007 06:45 AM
civiceg500
10
Sep 10, 2004 07:38 PM
zseeanz
Mar 24, 2004 02:41 PM
tornactive.com
May 3, 2002 06:17 PM
