parts sale-type R goodies, GSR head &stuff, cusco lsd, trannies, s2000 shortblock stuff
From: gravity rides everything...everything will fall, se GA/ne FL
don't waste my time please...you either got the money and want it or don't. way too many bitches and flakes
!pics will be up later this week (no camera right now). i'm taking a big break from this stuff
*great condition 4.40 final drive out of a del sol b16...great direct bolt in for the straight ls dog trannies. or great for a back up cuz i've seen sheared off teeth too many times(ring and countershaft)
-150 shipped
*stock 4.26 ls hydro final drive (ring and countershaft). maybe you want to switch to this who knows. or you want a back up for that one day.
-100 bucks shipped
*stock ls diff as well as a stock gsr diff.
-50 shipped either
*mint '00 usdm itr valve cover w/s2000 oil cap (same as obd2 white letter cap, but orange letters), gaskets, silver grommets
-110 shipped not for sale anymore
*'00 gsr head (frankenstein ready, plugged, comes with ss -4 line and t's & fittings), new valve seals(installed 3 months ago), itr valves (intakes were brand new 3 months ago), stock springs & retainers, solenoid&pressure switch, hondata intake gasket, gsr intake (no sensors), t.b. opening matched to itr throttle body), obd1 or 2 injectors (no rail), only have 1st gen b16 cams to go with it since the ******** scammer in my sig had to pull a scam on the usdm itr cams.
-fresh full port job (deshroud&polish&cc chambers, pocket port/bowl blend, runner casting cleaned, refreshed valve seats, untouched valve guides.
-$850 shipped for the bare w/ itr valves stock gsr valvetrain and cam caps/hardware. will have pics up later cuz you gotta see.
not for sale anymore cuz it came out too nice i had to use it
*arp new style (allen head tip) gsr head studs, torqued once and only once
-80 shipped<---SOLD to scoop
*p72 ecu
-180 shipped
*'00 itr stock throttle body w/ map and tps
-220 shipped sold to quick4
*hydro gsr tranny in absolute perfect shape, clean, and no grinds (no pics yet )
-650 shipped. sold to jungletronic
*del sol b16 tranny (brand spanking new 3-4 synchro set)
-750 shipped parted out
sold*dope *** Cusco lsd 1.5 for hydro b16/ls i.d. ring gears, used a month in ^--b16 tranny, comes w/ close case bearings (at least one or both should be replaced)
-500 shipped
(900 new) NO RING GEAR INCLUDED
*'00 itr flywheel in grrrrreat condition
-100 bucks shipped sold
[img]
http://www.imagestation.com/picture/...5.jpg[/img]
*DSM 450 set (green tip)
-65 bucks shipped
*carbon kevlar fuel pump cover for eg chassis, bling blao!
-50 shipped sold
*LS 5th gear set (hydro), main and countershaft gears, great shape, save gas now is the time
-55 shipped sold no fear i have another set still for sale
*real, red, jdm itr 'H' emblems, front and back(heated up and shaped to lay curve of a eg hatch gate), great condition
-50 shipped
*'00 secondary O2 in great shape and working order from itr, also have a '00 primary with no clip but works perfect.
-45 shipped
*'00 itr usdm manifold, dp, heatshields, great condition on stuff
-60 bucks local, 75 shipped
*'00 s2k oil pan, nice aluminum heatsinks
-75 bucks shipped
*'00 s2k crank pulley (balanced, single acc pulley, harmonic dampener) might work great to underdrive a h22 civic
-50 shipped
*'00 s2k oil cooler, o-ring, and extension bolt, can be used on b, d, f, and h series blocks
-55 shipped,<---SOLD to scoop
on a gsr block:
*'00 s2k crankshaft, good condition, no spun bearings
-180 shipped
*'00 s2k bare block w/ main cap girdle, chain case cover, needs aftermarket sleeve job
-160 shipped, 100 pick upsold to z10rob
misc. s2k shortblock stuff:
------------------------------------PAYPALs +3%----------------------------------------
-probably more stuff when i remember...pm me or post interest. i got more than enough vouches on heavy shipping items (trannies, blocks, wheel sets, etc) to big $$$ items dealings (ems, itr trannies, etc). no trading items at the moment. thank you.
*since being scammed recently, no item will be shipped till cash is in my hand.
Modified by not so civic at 7:46 PM 11/27/2004
-150 shipped
-100 bucks shipped
-50 shipped either
*p72 ecu
-180 shipped
-500 shipped
[img]
-65 bucks shipped
-50 shipped sold
-50 shipped
-45 shipped
-75 bucks shipped
-50 shipped
on a gsr block:
-180 shipped
surprise
. i'm not sure what the hell i'm doing here...i don't think i can finish what i started due to lack of funds. getting old and loosing interest in all this also.
if you're semi local, i can install (ls/b20/vtec, five speed conversion, tranny swappage, lsd install, etc) these parts for a fee. and i can deliver.
. i'm not sure what the hell i'm doing here...i don't think i can finish what i started due to lack of funds. getting old and loosing interest in all this also. if you're semi local, i can install (ls/b20/vtec, five speed conversion, tranny swappage, lsd install, etc) these parts for a fee. and i can deliver.
'before i go lay some welds' bump
pics taken. i will post up later this afternoon.
some pics up now...more to come.
ok let me try a few more times here...
gsr arp's and 'es' oil cooler sold to SCOOP.
Bump for a good seller.....got my tranny case from him and had super fast shipping!!
sheez no interest at all...can a man get some offers here? don't be skerred.
*bare gsr head might be sold as well as b16 tranny...nothing solid yet though.
