second gen zc swap
anyone out there KNOW which axles I am supposed to use for OBD 1 zc / zc lsd trans.
90-93 teg 1/2 shaft too long but proper mounting position
87 teg 1/2 shaft right length but mounting position totally wrong
I used the long axle and it seems too short
what distributor am I suppposed to use
91 crx si distributor does not fit
87 integra does not fit
95 del sol si doesnt fit either
you need a ZC intermediate shaft (only one that fits) and 90-93 Integra axles - do you plan to run it OBD1? - if so, you need a TD43U distributor and P29 ECU - if you plan to run it OBD0, you need 88-89 Integra distributor and the Cylinder Position Sensor for the end of the exhaust camshaft
afstlsvtec
19
Mar 19, 2002 04:03 AM
ZCREX
Nov 27, 2001 04:16 PM
