H22a4 and H22a1 heads/block interchangable?
Hey guys, quick question that I am not to sure of, right now I have a H22a4 in my car now, and the old h22a1 head is sitting is my basement, needing a rebuild... So what I am asking is with the H22a1 head work with my H22a4 block? I am going to build the H22a1 head to the honda-challenge rulebook specs if I can use it.. TIA
..but those are the blocks, both series have the same p13 head. Look at your engine when you get home or now, above the exhaust ports you should see p13 stamp. This true for 92-96 motors, and 97+.
Does anyone know what the differences between H22A1 and H22A2's are?
I have the H22A2 in my UK 4th Gen Lude VTEC. No one seems to know the differences between types...
H22A1 -> H22A2 etc
Can anyone list the differences from A1 to A7
H22A1 -> H22A2 etc
H22A1 -> H22A2 etc
H22A1 -> H22A2 etc
Andrew
Just remember that the headgasket is different. Use the 97 and up headgasket or you will have problems.
Andrew
What problems can arise if you use the 4th gen head gasket?
Yes it has to do with the coolant passages. THe headgaskets are not interchangeable. I had a friend that did that and he blew the headgasket out. Alot of people dont know that they are not interchangeable.
