possible to remove passenger airbag
Old Dec 19, 2001 | 07:32 PM
citanest's Avatar
New User
Default possible to remove passenger airbag
Is it possible to remove the passenger side airbag and leaving the cover there? or the airbag is in conjunction with the cover? (like the driver side).
thanks,
Old Dec 19, 2001 | 07:47 PM
lotus's Avatar
New User
Default Re: possible to remove passenger airbag (citanest)
All one component, but you can disconnect the wiring under the dash ( yellow
plug I believe ) and take out the warning lamp bulb from the inst cluster...
Works out to the same thing.
Old Dec 19, 2001 | 07:50 PM
BoM's Avatar
BoM
Default Re: possible to remove passenger airbag (lotus)
i hope your passenger knows your doing this
why are you taking it out ?
Old Dec 19, 2001 | 08:56 PM
paul_573's Avatar
Default Re: possible to remove passenger airbag (BoM)
I bought a dash from a 98 teg and it had no passenger bag. The cover was still on, so I'm assuming you can do that no problem.
Old Dec 19, 2001 | 08:58 PM
Andrew Sites's Avatar
The dash cover can be removed from the airbag casing and put back into the dash.
Old Dec 20, 2001 | 01:31 AM
citanest's Avatar
New User
I don't have a passenger as it's a race car.
Old Dec 20, 2001 | 02:05 AM
Ryuji's Avatar
New User
In Europe, R has no airbag...
Neither passenger nor driver...
Old Dec 20, 2001 | 04:12 AM
Lip's Avatar
Lip
Default Re: possible to remove passenger airbag (Andrew)
andrew is right. its easy
Old Dec 20, 2001 | 05:48 AM
Mike K's Avatar
Default Re: possible to remove passenger airbag (Lip)
For those interested, if the passenger airbag is removed, the SRS module won't allow the driver's side airbag to deploy.
Just a tid bit of info...
I removed both.
Screech`:)
Dec 7, 2010 09:10 PM
johnclaunch
34
Sep 11, 2008 12:58 PM
hondastrtracr
Feb 28, 2008 08:41 PM
JRciv
Apr 11, 2005 02:00 PM
Sassafrass
Jan 26, 2004 03:45 PM
