92 eg problem
I Need serious help... this problem occured yesterday to me... my car just turned off on me driving down the block... i tried everything 2 start it and nothing happened... i went replace the fuse under the hood for the ECU and 1.2.3 it started... later on that night the same inncent happened changed the fuse again n it started.... i parked the car 4 the night... when every i go 2 take off on 1st gear the car just turns off.... i have 2 replace that fuse 4 the car 2 start again.... can anyone help...the car only turns off when i put the car into gear and go 2 take off!
I suppose you could always hot wire the connection so there's no fuse to shut down. You should try bridging the gap with a piece of wire, driving around the block and then letting your car sit for a couple minutes. Try and start it again and see what happens.
91sedan_kid
Jan 19, 2025 09:13 PM
seedlesseg4
18
Feb 19, 2014 11:37 AM
