major issues need help immediately
Old Dec 19, 2001 | 07:25 PM
Mr. Softee's Avatar
Default major issues need help immediately
ok i just burned 2 quarts of oil in the last 500 miles. I just took out my plugs, they are:
a. black.
b. oil as ****.... on the thread to the electrode... not above.
it's not spark plug o rings because i just replaced mine and even if that was it it wouldnt get on the electrode.
please please help... i just rebuilt my engine... i dont know what this is!
compression test gave me good numbers across the board! Anyway to tell if its valve seals from this? anyone? please?
Old Dec 19, 2001 | 09:12 PM
sgT's Avatar
sgT
Default Re: major issues need help immediately (97lstegra)
sounds like too much oil for valve seals.
I would guess that its the rings.
Did you hone the block when rebuilding?
Did you position the rings properly?
Old Dec 19, 2001 | 09:18 PM
Mr. Softee's Avatar
Default Re: major issues need help immediately (sgT)
the rings were gapped correctly and the rings were positioned correctly as well. everything was to spec and the block was properly honed. Is it possible that the valve seals were installed on the wrong side? I heard that the intake/exhaust sides use different valve seals.
Old Dec 19, 2001 | 09:35 PM
sgT's Avatar
sgT
Its possible, but thats just really a temperature related issue.
granted bad things can happen from that as well like valves getting stuck open.
Did you assemble the motor? or did someone else?
Old Dec 19, 2001 | 11:18 PM
Wildohiorice's Avatar
New User
sounds like rings to me, check your oil make sure u didn't put to much in.
Old Dec 20, 2001 | 04:01 PM
Mr. Softee's Avatar
Default Re: major issues need help immediately (Mr. JDM)
i didnt put too much ******* oil in ... lol.
I put new valves / valve seals in at the same time. What coudl have gone wrong? I had it professionally assembled but the place seemed somewaht newbie to hondas.
-sam
Old Dec 20, 2001 | 04:10 PM
98TypeR's Avatar
it sounds like the rings to me, what were your compression numbers? did you do a leak down?
Old Dec 21, 2001 | 08:54 AM
Mr. Softee's Avatar
Default Re: major issues need help immediately (98TypeR)
i really doubt its the rings. i did perfect on a compression test. a leakdown wont tell me anything about the rings. i intend to do a leakdown next week.
Old Dec 21, 2001 | 01:01 PM
sgT's Avatar
sgT
So it may not be a problem with the compression rings, but the oil control
rings may have a problem.
G3teg96
Aug 20, 2011 05:00 PM
Built4Battle
Oct 23, 2010 03:55 PM
Panda Eg6
May 29, 2009 07:16 AM
lilshady6796
May 24, 2009 04:07 PM
IgnitionZ05
Apr 12, 2007 11:20 AM
