how to tell the difference from jdm b18c1 and b18c5
Old Oct 25, 2004 | 04:29 PM
slosi's Avatar
Default how to tell the difference from jdm b18c1 and b18c5
i know u guys might think this is a repost but i'm been searching everything i can't find it.
i'm trying to find if there is a different between the JDM b18c5 and the JDM b18c1 blocks, i have a car with a jdm B18C, it might have a type r manifold but is there any other way to tell from the block?
i have a pic of it but not the block just the top of it so if u wanna check out the throttle cable location if that means anythign because i herd it's different?
Old Oct 25, 2004 | 07:02 PM
Chris F's Avatar
Default Re: how to tell the difference from jdm b18c1 and b18c5 (slosi)
Blocks are identical, besides the stamp.
Your search for b18c5 differences returned 14 results.
https://honda-tech.com/zerothread?id=261965
https://honda-tech.com/zerothread?id=85191
Old Oct 25, 2004 | 07:46 PM
ITR 2K's Avatar
There is no JDM b18c5, or JDM b18c1.
Old Oct 25, 2004 | 09:11 PM
slosi's Avatar
Default Re: how to tell the difference from jdm b18c1 and b18c5 (ITR 2K)
ya i know but how am i going to know if it's type r or not!
i might be buying a a civic with either a gsr or type r, at first it was thgouh ti was a gsr motor but then after someone who knows more then me, checked it out and said it was a type r b/c it has the intake manifold, on the block it has the regualr b18c, there is no tranny, come on guys i need something, anything what u guys got?
Old Oct 25, 2004 | 09:15 PM
Opie's Avatar
Intake manifold and LSD stamp on the tranny.
"I come from Canada and dey tink i'm sloow"
Old Oct 25, 2004 | 09:23 PM
slosi's Avatar
Default Re: (opie)
****** stupid block!!!why can't they just put a 1 or a 5, it's got the r intake manifold but i dont think it's got the LSD, which means i got 1 of both!!and i can't take apart the engine to look at the pistonss!!!LOL!!!!
anyone else?
Old Oct 25, 2004 | 09:43 PM
WickedKP's Avatar
Default Re: (slosi)
On the head of a type r right behind the dist. there is a stamp that say P30, cause the type r head is a port and polished b16a head.
Old Oct 25, 2004 | 09:57 PM
Cyber ITR's Avatar
Default Re: (WickedKP)
i also believe that all type r heads has green paint close to the dizzy
Old Oct 25, 2004 | 10:17 PM
cheezthis's Avatar
Some JDM GSR (SIR-G or whatever it's called) also had LSD as well...so that stamping might not dictate what engine it is.
Without pulling it apart, I'd check the head stamping (P72 = GSR) and intake manifold.
Old Oct 25, 2004 | 10:38 PM
ITR184's Avatar
you might be able to tell by the oil cooler. now that I think about, other JDM motors may have the oil cooler also.
Old Oct 25, 2004 | 11:27 PM
JDM-TypeRteg's Avatar
besides the stamp the block itself shows no apparent differentce, maybe pulled apart but....... not sure otherwise
Old Oct 26, 2004 | 12:02 AM
FatBoy4door's Avatar
well if it has a type r manifold its either a type r or a pos gsr with b16 head, does vtec crack hard or is it ***** b16 style?
Old Oct 26, 2004 | 12:10 AM
cheezthis's Avatar
Default Re: how to tell the difference from jdm b18c1 and b18c5 (FatBoy4door)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FatBoy4door &raquo;</TD></TR><TR><TD CLASS="quote">well if it has a type r manifold its either a type r or a pos gsr with b16 head, does vtec crack hard or is it ***** b16 style?</TD></TR></TABLE>
Stupid post
I think the user has plenty of info to figure it out now. Good luck.
Old Oct 26, 2004 | 08:59 AM
slosi's Avatar
Default Re: how to tell the difference from jdm b18c1 and b18c5 (cheezthis)
thx for all the posts, i'm suppose to see the engine tonight, i'll get back to u see what i come out with, oh ya wats a dist.?
Old Oct 26, 2004 | 02:35 PM
mugenracer's Avatar
A JDM B18C GSR motor will have P72 stamped on the head. A JDM ITR motor will have P30-1 stamped on the head. If its a JDM GSR motor, an ITR inlet manifold will not bolt to it, and i'm sure you know what a GSR I/M looks like!
Old Oct 26, 2004 | 04:00 PM
ITR 2K's Avatar
Dude, you're a moron. VTEC crack hard?!?! ***** B16?!?!? If anything, the VTAAAK on a gsr motor is fairly noticable because of the gay *** manifold it comes with. The B16 screams because it comes with a similar ITR manifold. I think you already recieved enough info. to learn how to tell the difference. You should go check the motor, and just let it be, and stop making yourself look like a complete dumbass.
Old Oct 28, 2004 | 02:35 PM
slosi's Avatar
Old Oct 28, 2004 | 02:53 PM
ejONE.mike's Avatar
i bought a jdm itr motor from steve at HMO and he said you can tell if its jdm if is say b18c21xxxxx for a 98+ and b18c16xxxxx for a 96-97 jdm itr. so if its not one of those, its not a gsr. hope that helps
drift4jesus
Nov 30, 2006 04:07 PM
eddie_jdm
38
Mar 9, 2005 12:24 PM
B18Redline
Dec 20, 2004 12:37 AM
fast95civic03
Aug 28, 2004 09:39 PM
endlessdv
May 27, 2004 05:26 PM
