Rear rubbing and vibration
Old Oct 25, 2004 | 03:42 PM
crxgator's Avatar
Default Rear rubbing and vibration
ok this is killing me, but im having a huge rattle/vibration coming from the right rear, i ripped apart my interior and nothing is loose or could cause it, but it does...
also, it sounds and feels like my right rear wheel is rubbing...i have no clue why, im running 185/60/14 tires and it just started to happen. anyone have any clues? shocks are kyb agx, tried it on all settings still the same. has new RTA bushings, new Rear LCAs as well...
also if i shake my steering wheel when im driving, i can make the noise get louder and softer with each shake...
anyone have any clue what this could be?
wheel bearing maybe?
Old Oct 25, 2004 | 03:43 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: Rear rubbing and vibration (crxgator)
You guessed it, wheel bearing or trailing arm bushing.
Old Oct 25, 2004 | 03:44 PM
crxgator's Avatar
Default Re: Rear rubbing and vibration (1 point 6)
well the trailing arm bushing is brand new from honda...now anyway to make sure its my wheel bearing? i dont want to replace a 100 dollar part and it still do it...
cause with the fronts, it makes a metalic scraping sound...and im not hearing that...
Old Oct 25, 2004 | 03:46 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Jack the back end up and spin the wheel, or just give it a tug if it has play its the wheel bearing. Wheel bearings tend to make a gang of noise when going over bumps, like driveways and speedbumps. Does it do this?
Old Oct 25, 2004 | 04:09 PM
drussell4801's Avatar
this will either be really right or really wrong, but make sure your damn exhaust isn't vibrating against the bottom of your car.
Old Oct 25, 2004 | 04:11 PM
crxgator's Avatar
Default Re: Rear rubbing and vibration (drussell4801)
at the time, i had no exhaust...
i just put one on...
Old Oct 25, 2004 | 04:12 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
I would jack the rear up and see if there is any play with the the rim/tire.
Old Oct 25, 2004 | 04:15 PM
crxgator's Avatar
yeah, i guess that will be next on the agenda, i finally put an exhaust on it after a year...
but i did more important things so dont think im neglecting the car...
Old Oct 25, 2004 | 04:17 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
**** on my EF 4dr the exhaust fell off and I never put one back on.
Old Oct 25, 2004 | 04:20 PM
crxgator's Avatar
thats how it was for me for about a year... it broke off right before the muffler attached to the midpipe...dam that thing sounded horrible for a year, but oh well, i rather do my bushings, suspension/steering and maintance than worry about a shitty exhaust...
Paprika
Aug 25, 2006 08:24 AM
Ill
Sep 12, 2004 07:06 PM
jdmstreethatch
Aug 11, 2004 05:36 AM
jdmstreethatch
Aug 7, 2004 01:40 PM
BrandonClaps
Jun 20, 2003 11:20 PM
