Replaced Battery And Car Won't Crank..........Help!
I replaced the battery in my '90 Civic Wagon with a new one and car won't even crank now. Can anyone give me suggestions as to where I should look? Did I blow a fuse or something when hooking the cables up?
Thanx for any help!
Thanx for any help!
different things could have happened...
first off- does you car have an alarm--> kill switch goes off when battery dies or is replaced.
if not that i would start trouble shooting with either a voltmeter or one of those continuity light tester and check the ignition and starter...
but yes.. also check fuses dealing with ignition.
i don't know what else to tell you/// hope you get it running.
chwy_thoj
chwy_thoj
Did you accidentally hook up the wrong cables to the wrong terminals? Check your battery fuse in the underhood fusebox.
Make sure battery cables are tight.
quetzalcoatl
Oct 1, 2009 02:55 PM
dc2teg2006
Mar 28, 2009 05:31 PM
