Turbo hitting radiator...
its normal, you should have switched to a half size radiator either aftermarket or del sol vtec dual core...im in the process of ordering one for my setup soon...
I fabbed up some new top brackets that tilt the top of the radiator towards the front of the car, it will give you over 1/2" of clearance easily.
My turbo is touching my PWR half stack radiator. It is touching were the were the coupler from the turbo is. Its hasnt hurt it so far. Is all i have to do is clock the turbo some more and it will not touch it but that is alot of work.
.. What manifold are you running?
