Spoon Rotors?
Old Dec 19, 2001 | 04:46 PM
Prelusion98's Avatar
Default Spoon Rotors?
Are the Spoon Sports Type-R rotors compatible with BB6 Preludes? I know that the calipers are compatible. If not, what rotors might you recommend? I would prefer slotted rotors ONLY that are lightweight and slightly larger in diamater.
Old Dec 19, 2001 | 04:57 PM
bb6h22a's Avatar
Default Same rotor..
Robert,
The 97+ ITR's and 97+ Preludes share the same front calipers and rotors. So, anything that will fit a 97+ ITR will fit a 97+ Prelude. As far as lightweight alternatives to the rotor, Fastbrakes sells front rotors w/ aluminum hats, that weigh considerably less than stock pieces. They are however, very pricey.
Another note, you really wont save that much weight by using slotted vs. solid rotors, you'll get slightly better pedal feel, but thats about it. All in all, your better off getting a solid Brembo blank.
[Modified by bb6h22a, 6:15 PM 12/19/2001]
Old Dec 20, 2001 | 04:26 AM
LudeBehavior's Avatar
New User
Default Re: Same rotor.. (bb6h22a)
Spoon is really expensive, I agree with going with brembo.
Old Dec 20, 2001 | 05:10 AM
DR's Avatar
DR
Default Re: Same rotor.. (LudeBehavior)
Unless you want pretty brakes go with Brembo blanks.
Old Dec 20, 2001 | 06:36 AM
Honda318dx's Avatar
Default Re: Same rotor.. (DR)
Brembo
Old Dec 20, 2001 | 07:18 AM
mrlegoman's Avatar
Default Re: Same rotor.. (Honda318dx)
Go with Advance Auto. 25$
Two-year warranty.
They get worn and you take them back and they replace then for free.
I lot cheaper than Brembo and (personal opinion) they work just as good with the right pads.
Old Dec 21, 2001 | 04:25 PM
Thanks Hubert.
I was actually requesting slotted rotors, as opposed to cross-drilled rotors, for their increased strength and durability.
Thanks everyone for your replies. When the time comes (hopefully it won't be too long!), I will consider your advice.
xbB
Oct 31, 2004 06:41 AM
luckypon7
Feb 3, 2004 09:10 AM
Jaesung
Jul 4, 2003 10:44 AM
shinchan
Mar 27, 2003 11:12 AM
Rboosted717
Sep 24, 2001 03:43 PM
