computer problems
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reason »</TD></TR><TR><TD CLASS="quote">What computer did you buy?</TD></TR></TABLE>
Well? What ECU?
Sounds like you bought an ECU from an OBD-1 car which has 3 plugs.
OBD-0 only has 2 plugs and you would need a jumper/conversion harness to make the OBD-1 ECU work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">Well? What ECU?
OBD-0 only has 2 plugs and you would need a jumper/conversion harness to make the OBD-1 ECU work.</TD></TR></TABLE>
when was the last time YOU looked at an ecu
Obd0 has 3 plugs, obd1 has 3 plugs
it has three plugs but one is smaller. theres also same amount of wires to each connector but the clip is differant. the computer is for a 92 ls intgra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback_al »</TD></TR><TR><TD CLASS="quote">
Obd0 has 3 plugs, obd1 has 3 plugs</TD></TR></TABLE>
So what's your point?
I have 9 finger and 12 toes.
Ok - you're right.
Here's some helpful info to diferenciate between OBD-0 and OBD-1
If you count the pins in the plugs and find the plug that has the MOST pins in it -
(I'm counting <U>available</U> wire spots - with or without all the pins.. just like they count them in the manuals)
OBD-0 has 20 (and the other two are a 18 and an 16 pin)
OBD-1 has 26 (and the other two are 16 and 22)
Obd0 has 3 plugs, obd1 has 3 plugs</TD></TR></TABLE>So what's your point?
Ok - you're right.
hehe, you've been on honda-tech for 2 years with over 2 thousand posts... wtf.
next time do some research before you open your mouth. stop giving out misinformationg
GreddySi99
Oct 26, 2003 10:11 PM
