b20-vtec in a 92 teg
anybody know what all parts i would need to run dis set up on my car?i got a b20 in my teg runnin on ls tranny right now. would i be alright jus buyin an b16a1 motor, tranny, ecu, or should i get the full swap? any info greatly appreciated.
What are you trying to do? I take it you have a b20 stock right now, and you want to run a vtec head on it. If thats the case, why would you buy a b16 swap?
If you want to run a vtec head on the b20 block, well first off you need a vtec head. There is a bunch of other related parts that you are going to need, and I suggest you do some searching before you post another thread that makes no sense.
Try reading this too. A pretty good write up on a LS/VTEC the process is basically the same.
http://sportcompactcarweb.com/tech/0411scc_hybrid/
swap_killer7079
Feb 2, 2011 05:06 AM
