need help..and advice
Old Oct 24, 2004 | 08:55 PM
Ek9_6's Avatar
Default need help..and advice
spark plug wire snaped on my ek..i got the barrel of the wire out but the base of it is still stuck onto the plug..blocking the bolt for the socket for removal..any sugestions to removal or do i have to take apart the head....
Old Oct 24, 2004 | 08:58 PM
Luserkid's Avatar
Default Re: need help..and advice (Ek9_6)
What part of the plug is on the spark plug? did you get all the rubber off? If so just get a long *** deep socket and take it out.
Old Oct 24, 2004 | 09:47 PM
RC000E's Avatar
Default Re: need help..and advice (Luserkid)
Get yourself a long *** set of needlenoses or some really strong *** adhesive. Put the adhesive on the end you do have and shove it back in then let it set overnight. Thats about your chances...for god sake don't take the head off for that...there are always options. This is typical cheap wires...can't stand them.
Old Oct 24, 2004 | 10:10 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: need help..and advice (RC000E)
yep long needle nose pliers will work or use a long flathead screwdriver to pry it lose or break it up. The worst that would happen is you'll snap the top of the plug off, but you'll still be able to get a wrench on it.
PSU
25
May 28, 2012 07:51 AM
h22lude317
Jan 18, 2009 09:59 AM
Wilky
Sep 1, 2008 12:53 PM
Ef Whore
10
Apr 29, 2003 11:25 AM
B_CRUZ!
Feb 14, 2002 08:45 AM
