how much money to go 5 gears ????
if you are looking for a cheap reputable shop, it would cost you around 700-1000 dollars for a swap, depending on where you are, but the swap is pretty straightforward, so if you want to save a grand, i suggest you try it yourself.
I believe the TL and the CL from the same model year swap. The TL i know for sure has the same engine as the AV6. You should probably ask in the other honda/acura forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">you are looking at anywhere from $500-1000 in parts, and if you do it yourself, free labor...yes, it is worth it...</TD></TR></TABLE>
I stand corrected...
