need a chassie diagram. does anyone have one for the sir and si?
basically i'm looking for a diagram for the difference in the brake lines and what. trying to compare the differant between the rhd and the lhd
brake lines and fuel lines are on the same sides as the USDM, brake lines run on the right and fuel on the left. the only differents is the wire harness in on the right side becuase the fuse box is on the right side
i see. also another question for you then sir. is the frame the same? cause i want to use the support bean under the steering rack. and i need to know if that will fit on a usdm chassie. i think it will. but just making sure before i cut anyhing thanks
i have the sir uk edition helms manual I gave a copy to rodney hit him up and see if you can downlad it from him, i dont have a high speed connection so it would take years to download from me if he doesnt have it ill give it to him next time i see him, tell him jimmy sent ya if he asks
Type V
Aug 26, 2005 12:33 PM
