Resistor Box (problem with it..i have searched!!!)
Hey guys,
Doing an 450CC injector install on my car today and ran into a problem. I installed 4 450CC injectors that were off a working talon. Anyways, I wired up the yellow/black injector wires to each black wire on the box and then took the other side of the yellowblacks (from engine harness) and wired them to the single white wire on the resistor box. The car would NOT turn over and I could smell ALOT of gas.
I went back to stock injectors without resister box as I need my car..so i unhooked my wastegate
Is this a wiring problem or a resister box problem?
Quick reply. I went -40 all across the boards on the SAFC(until i can go to toronto to get it dyno'd on uberdata) that was working before with my stock injectors to compensate for the larger ones.
