clutch problems
Old Oct 24, 2004 | 05:33 PM
snatchbakman's Avatar
Default clutch problems
i changed a hydro. clutch in my 92 hatch. i drove it for a day and it seem cool. the next day as i was puling out of my garage i heard a sorta grinding noise as i was letting out the clutch. now it does it for nutral too i throught it might be my master slave cylinder b/c it was leaking a lil fluid. i got a knew one, bleed t one or twice.i stared it and it stil made the soound so i bleed it again and now the pedals dead it doesnt build any pressure to the slave cylinder. if i pump the control arm and crack the slave it spits so its holding pressure. but the pedals dead?? i dunno what to think?? please help.
Old Oct 24, 2004 | 06:09 PM
Default Re: clutch problems (snatchbakman)
also around the mastcylinder its wet and inside from the pedal is leaking also . i dunno if that might help.
Old Oct 24, 2004 | 09:30 PM
hatchi's Avatar
your noise is from the throwout bearing.
Old Oct 24, 2004 | 09:38 PM
dvang's Avatar
yeah thats most likely it throwout bearing
Old Oct 25, 2004 | 08:42 AM
JDM-GTO's Avatar
So did you change your master or slave cylinder? That is probably not related to the noise you are hearing, but if one is still leaking thats probably why you can't build pressure. If its leaking, its not working right.
Old Oct 25, 2004 | 10:24 AM
Default Re: clutch problems (JDM-GTO)
the slave cylinder is hold pressure so its not the. do you think i could be my clutch cylinder b/c its leaking inside the car by the pedal?
Old Oct 25, 2004 | 05:21 PM
so i replaced my slave cylinder and my master cylinder and i regained pressure from pedal. i bleed the line a few times. i figured i wasnt getting enough pressure to the throwout baering and that with the nosie might have been . welthast didnt work so i think my next move is to take the tranny back off and make sure everything ok in there.
Old Oct 26, 2004 | 11:06 AM
i noticed i dont think my axles started cliped in could that cause the noise i am hearing???? please help
Old Oct 26, 2004 | 11:07 AM
i ment "are" not "started" im a retared
Magicdrag0n
Transmission & Drivetrain
Jul 17, 2018 01:33 AM
pwnlude
Apr 23, 2009 07:16 AM
CapnKrunch
Dec 1, 2006 09:34 PM
hialeahzbg
Jun 28, 2006 09:08 AM
xsnrgsr
Jul 13, 2003 08:23 PM
