ok d series swap question...
Old Oct 24, 2004 | 04:14 PM
rice a roni's Avatar
Default ok d series swap question...
ok...since the b series is so popular i cant really find much on how to do a d16a6 swap into my hf. im guessing the bottom end is a direct bolt on but im not sure if the head and axles are just bolt ons. somebody let me know how to do this, i'd really appreciate this.
Old Oct 24, 2004 | 04:58 PM
RC000E's Avatar
Default Re: ok d series swap question... (allmighty2door)
You kind of contradicted yourself. You said a D16A6 SWAP, then asked about head compatibility. Are you interested in using the HF head, or completely swapping the motor? Axles match your tranny, so whatever tranny you use, thats the axles you keep in this case. The head from the 1.5 will work just fine, you may have some small issues, but it will work. It has been many years since I messed with Dseries motors heavily especially some 1.5's but it can't be too bad. If there happen to be any headbolt differences having both the 1.5's and 1.6's bolts will solve your issue. If I had to guess though I would say they are the same. It's all good man, just get it done.
Old Oct 24, 2004 | 06:22 PM
jlicrx's Avatar
D16A6 bolts directly into the HF - you need to use the HF engine harness - need to use the HF axles with whatever transmission (as long as it isn't a ZC transmission)
Old Oct 24, 2004 | 06:43 PM
notfastenough's Avatar
Also have to use the hf intake manifold.
Old Oct 24, 2004 | 10:09 PM
RC000E's Avatar
Default Re: (notfastenough)
You don't HAVE to use anything.
Old Oct 25, 2004 | 08:50 AM
Default Re: (RC000E)
ok guy...thanks. i was planning on using the hf head again unless i can get an si head.
Old Oct 25, 2004 | 09:05 AM
92integra_gs's Avatar
why would you reuse your hf head when the a6 head is so much aggressive than the hf?
i would just stick w/ the whole a6 setup if i we're you
Old Oct 25, 2004 | 09:13 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notfastenough &raquo;</TD></TR><TR><TD CLASS="quote">Also have to use the hf intake manifold. </TD></TR></TABLE>
ehh wrong answer
just use the entire a6 motor AND tranny w/ HF axles and Si (pm6) ecu. you'll be fine
Old Oct 25, 2004 | 09:22 AM
Default Re: (92integra_gs)
hmm...i dont know..i only found a good a6 bottom end so far so i'll just use the hf head for now.
Old Oct 25, 2004 | 09:42 AM
4g_civic's Avatar
Default also would like to know
i also would like to know if a6 would bolt right in to 89 civic std. i already did the mpfi swap. and i heard from my friend, that when he swap his d16a6 to his car (92 civic d15b7) the a6 motor isnt sitting there very good (tilted a bit). any help would be great. thanks
first time post.
Old Oct 25, 2004 | 09:45 AM
4drEF's Avatar
Keyboard Humorist
Default Re: also would like to know (4g_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4g_civic &raquo;</TD></TR><TR><TD CLASS="quote">i also would like to know if a6 would bolt right in to 89 civic std. i already did the mpfi swap. and i heard from my friend, that when he swap his d16a6 to his car (92 civic d15b7) the a6 motor isnt sitting there very good (tilted a bit). any help would be great. thanks
first time post.</TD></TR></TABLE>
Goes right in.
Old Oct 25, 2004 | 09:50 AM
4g_civic's Avatar
Default Re: (4drEF)
o cool. thanks
if i have any problem with the swap ill let you guys know.
Old Oct 25, 2004 | 10:18 AM
90 Si Hatch's Avatar
Default Re: (4g_civic)
i got a whole D16A6 for sale let me know any one
Old Oct 25, 2004 | 07:52 PM
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
ehh wrong answer
just use the entire a6 motor AND tranny w/ HF axles and Si (pm6) ecu. you'll be fine</TD></TR></TABLE>
well then....double wrong answer Forgot an A6 distributor.
skiracer8148
Apr 12, 2007 07:27 AM
kleanlscivic
11
Mar 11, 2005 03:32 AM
soundman
10
Oct 25, 2004 06:25 PM
project dc2
Aug 5, 2003 05:57 PM
Boosteddc2gsr
Jun 12, 2003 12:06 PM
