Bought new rubber and car pulls to side... help plz
Old Oct 24, 2004 | 12:35 PM
hellrazr1208's Avatar
Default Bought new rubber and car pulls to side... help plz
I finally got some new rubber, Falken Ziex 512, running 205/50R15 all around. Before I had the tires put on the car ran straight, but after it pulls to the right a little when coasting, and even harder when I'm on the gas... any ideas on wut it could be? Thanx in advance.
Old Oct 24, 2004 | 12:42 PM
ITR640's Avatar
check your tire pressures, my car will sometimes pull to one side becasue the pressures are different.
Old Oct 24, 2004 | 01:01 PM
Chris F's Avatar
Default Re: Bought new rubber and car pulls to side... help plz (hellrazr1208)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hellrazr1208 &raquo;</TD></TR><TR><TD CLASS="quote">I finally got some new rubber, Falken Ziex 512, running 205/50R15 all around. Before I had the tires put on the car ran straight, but after it pulls to the right a little when coasting, and even harder when I'm on the gas... any ideas on wut it could be? Thanx in advance.</TD></TR></TABLE>
Hmm. I have Ziex (205/45R16) and don't have that problem. Could be a problem with one of your tires.... I'd probably take it back or try swapping tires around to see if it is a bad tire.
Of course, check the tire pressure too... also see if one wheel is hotter than the other, if one of your front brakes were dragging it'd heat up the rotor/wheel. *shrug*
-Chris
Old Oct 24, 2004 | 01:49 PM
Justin Klemgold's Avatar
Could be a few things....bad alignment...different tire pressure...gotta start checking things off.
Old Oct 24, 2004 | 02:45 PM
ITR184's Avatar
Did you get an alignment when you had the tires put on? I don't trust some shops. If you didn't they might have adjusted it so you would be back sooner or later. I always check tire pressure after having tires mounted. I usually find about a 3-5 pound varation between left and right sides.
Old Oct 24, 2004 | 02:46 PM
Very true Cod Sac...sounds like they may have tweaked something...it's ashame people are shady like that...
Old Oct 24, 2004 | 03:43 PM
Beach Accord's Avatar
i have been to shops that put like 40psi in my tires and use an impact to put the wheels on.....
resulting in me bringing my own torque wrench and pressure gauge and adjusting at the local gas station....
check to make sure the shop didn't put one of the tires on backwards as these are directional tires....
Old Oct 24, 2004 | 04:41 PM
migs's Avatar
Cross rotate your front tires regardless if they are uni-directional or not.
Drive the car, if it pulls to the other side, its your tire. This is known as a radial pull. The tire should be exchanged if so.
Old Oct 24, 2004 | 05:25 PM
1Quikgsr's Avatar
i also have the ziex with no problem
90daXsi
Sep 21, 2008 04:53 PM
ej6hatchie
Apr 14, 2008 04:22 PM
Evolution-93-Ex
Feb 17, 2008 09:34 AM
94excoupeaccord
May 30, 2004 07:40 AM
Type R 702
Jun 14, 2002 10:33 AM
