Oil filter relocation.
Old Dec 19, 2001 | 01:07 PM
AutoXsi2000's Avatar
Default Oil filter relocation.
Any recommendations on which manufacture to go with? I hate going under the car to remove the oil filter near the firewall, then having oil drip all over my hand and face. sucks. Any advantages or disadvantages?
Old Dec 19, 2001 | 01:17 PM
brcivic411's Avatar
Default Re: Oil filter relocation. (mano77)
u can build your own... http://hybrid.honda-perf.org/tech/oilcooler/index.html
i know that B&M provides one with their oil cooler kit also.
Old Dec 19, 2001 | 01:58 PM
Endless's Avatar
Chikra sells one. Sumit sells it.
Old Dec 19, 2001 | 09:11 PM
Mista Bone's Avatar
D Tranny Guru
B&M SUCKS!!!!!!!
The adapter doesn't fit, it won't tighten down onto the block. I used a Perma-Cool adapter (universal kit) to fit a oil cooler. But the new filter (Ford) is still mounted in same spot. Good luck find a spot to mount the relocation kit, I could not find any. Maybe if car had no A/C you could mount it on the inside LF frame rail.
BTW I've never had to crawl under car to get filter off. I just reach behind intake and twist. If it is too tight, then you put it on too tight!
Old Dec 20, 2001 | 03:46 AM
BakedCookies's Avatar
Default Re: Oil filter relocation. (Mista Bone)
I agree, I take off my filter from the top, jack up the car slide the pan under and undo my oil plug from the side of the car, i never even get under my car for an oil change... but my moroso pan makes getting to the plug alot easier..
LUDEcidDream
Mar 2, 2011 10:11 AM
3s0n3
May 4, 2006 04:06 AM
Boilermaker1
May 3, 2005 08:32 PM
cre18
22
Aug 13, 2004 09:48 PM
Austin
Nov 26, 2001 04:03 PM
