Oil filter relocation.
Any recommendations on which manufacture to go with? I hate going under the car to remove the oil filter near the firewall, then having oil drip all over my hand and face. sucks. Any advantages or disadvantages?
Re: Oil filter relocation. (mano77)
u can build your own... http://hybrid.honda-perf.org/tech/oilcooler/index.html
i know that B&M provides one with their oil cooler kit also. |
Chikra sells one. Sumit sells it.
B&M SUCKS!!!!!!!
The adapter doesn't fit, it won't tighten down onto the block. I used a Perma-Cool adapter (universal kit) to fit a oil cooler. But the new filter (Ford) is still mounted in same spot. Good luck find a spot to mount the relocation kit, I could not find any. Maybe if car had no A/C you could mount it on the inside LF frame rail. BTW I've never had to crawl under car to get filter off. I just reach behind intake and twist. If it is too tight, then you put it on too tight! |
Re: Oil filter relocation. (Mista Bone)
