whats this on my Throttle BODY?
Old Oct 24, 2004 | 11:52 AM
thrty8street's Avatar
Default whats this on my Throttle BODY?
its the missing thing, i think its a sensor, does anyone know what it is and/or what part number.
Old Oct 24, 2004 | 11:53 AM
Default Re: whats this on my Throttle BODY? (thrty8street)
oh yea this is a d16z6 TB
Old Oct 24, 2004 | 11:55 AM
Archidictus's Avatar
Unceasing Measure
I think that's the TPS sensor location, seeing as the inner parts of that will be moving when you open and close the butterfly.
Old Oct 24, 2004 | 11:56 AM
egsleepercivic's Avatar
What ^^^^^ said
Old Oct 24, 2004 | 12:02 PM
2fast4u831's Avatar
I'm really 2slow
tps sensor. You need that in your car
Old Oct 24, 2004 | 12:27 PM
Default Re: (2FAST4U831)
how do i take my old one off, and how do i put it on, theres not screws or bolts
Old Oct 24, 2004 | 12:52 PM
Unceasing Measure
Default Re: (thrty8street)
It sure looks like there are two screw locations there to me . If you're having trouble moving sensors around, just swap the entire throttle body and be done with it.
Old Oct 24, 2004 | 01:07 PM
B_CRUZ!'s Avatar
you have to notch the screws with a dremel.
Old Oct 24, 2004 | 01:09 PM
burningwrek's Avatar
Default Re: (b_cruz)
yea, i had to notch mine off my old civic ex tb when i switched to my gsr tb. i just notched the screws, unscrewed em out, put the tps on the gsr tb and i was good to go.
Old Oct 24, 2004 | 01:12 PM
G U E C O's Avatar
i think thats a tps sensor
Old Oct 24, 2004 | 01:16 PM
dogfood's Avatar
You may have to recalibrate the tps when you switch it over, you're better off just swapping the entire tb
Old Oct 24, 2004 | 01:33 PM
Redline96LX's Avatar
* B A N N E D *
Yes, its a Throttle Position Sensor, and its not the most fun thing to **** with.
Old Oct 24, 2004 | 02:33 PM
rodrez
Guest
Posts: n/a
Default Re: whats this on my Throttle BODY? (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">Yes, its a Throttle Position Sensor, and its not the most fun thing to **** with. </TD></TR></TABLE>
true that, i use a cut off wheel to make small cuts in the screw...then you can use a standard screw driver to turn it out
Old Oct 24, 2004 | 03:28 PM
Default Re: whats this on my Throttle BODY? (rodrez)
is there any difference between a b15b7 and d16z6 tps sensor?
Old Oct 24, 2004 | 03:30 PM
v4lu3s's Avatar
RTFM
jsut abotu every 88+ honda TPS is the same afaik.
coupe_hybrid
Aug 27, 2004 09:39 AM
Redsim
Jun 11, 2003 09:37 PM
Inaniac
Oct 21, 2002 12:34 AM
deacs
Oct 7, 2002 10:30 AM
SIcivic10
Sep 29, 2002 05:33 PM
