Help! Crankshaft Pulley
counter clockwise like every other bolt.. you got to use a breaker bar and 19mm socket.. and btw you will need a strap wrench or chain wrench to counter the pulley from rotation..hth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichatch27 »</TD></TR><TR><TD CLASS="quote">wont that make the bolt expand? Or warp the pulley somehow?
thats why i said propane - it wont warp anything at all, it's not hot enough...
heat helps because it melts the thread locker. It's even more important wishbone bolts and lower control arm bolts.. why do you think people break them all the time?
take a close look and you'll see a hole filled with blue threadlocker on those bolts..
</TD></TR></TABLE>thats why i said propane - it wont warp anything at all, it's not hot enough...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichatch27 »</TD></TR><TR><TD CLASS="quote">i used a 1/2 drive and impact sockets with a 3 ft bar!!</TD></TR></TABLE>
thats wont work need something bigger and longer (20" to 24" is the ideal)...you need more torque for the problem....and then you can even reinforce that with a lead pipe... or any pipe would do
Is the motor still in the car? I have this same problem busting the bolt.. It is a pain in the *** with a breaker bar. Just take it to a tire shop.. they will take it off for you. It is three second job with an air wrench. It shouldnt cost you more than five dollars.
put a pair of vise grips on the pulley then use a breaker bar to rotate the the bolt counterclock wise the visegrips shoudl get stuck on frame and keep pulley in place. It worked once for me so its worth a try.
DEF
DEF
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sellari »</TD></TR><TR><TD CLASS="quote">Is the motor still in the car? I have this same problem busting the bolt.. It is a pain in the *** with a breaker bar. Just take it to a tire shop.. they will take it off for you. It is three second job with an air wrench. It shouldnt cost you more than five dollars.</TD></TR></TABLE>
how would you get home if the motor is still in the car
Just go to a shop and have them break it loose with a impact wrench. Then have them tighten it back up. Now that they have broke it loose, it should be easier for u to remove. Btw, my 500 ft. lb. gun wasnt enough so i had a friend work his magic with his 650.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">thats wont work need something bigger and longer (20" to 24" is the ideal</TD></TR></TABLE>
3 feet is longer than 24 inches...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">thats wont work need something bigger and longer (20" to 24" is the ideal)...you need more torque for the problem....and then you can even reinforce that with a lead pipe... or any pipe would do </TD></TR></TABLE>
i dont see what the big deal is. i got mine off with the car in gear, brakes locked up and a 18" breaker bar. you guys must be "girlie men" lol jp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>yea i only got a 18" breaker bar too but i use a pipe to put more torque to it.. i said ideally 20"to 24"(2ft) is ideal... but yea that damn bolt is a bitch to come out...lmao...
MagicUnicorn
24
Apr 28, 2022 02:45 PM
awjuhl
14
Jan 22, 2012 04:43 PM
