h22a fit in?
Old Dec 19, 2001 | 11:51 AM
Grimm's Avatar
Default h22a fit in?
Will a h22a fit into a =96 civic ex? or is the b18c-r the largest engine that would fit.
Answer = probably not.... b18c-r is the best thanks guys
[Modified by Grimm, 4:57 PM 12/19/2001]
Old Dec 19, 2001 | 12:11 PM
Spade's Avatar
Default Re: h22a fit in? (Grimm)
yes it will fit but, there are issues, do a search for H22 and you will see the arguements pro and con.
Old Dec 19, 2001 | 02:03 PM
976's Avatar
976
New User
Default Re: h22a fit in? (Spade)
H22A is 2.2 liters. The B18 is of course 1.8 liters. The B18 with no doubt fit, however the H22A is larger it will take more room, more adjusting...
Old Dec 19, 2001 | 04:31 PM
SkotEZ's Avatar
H22 will go in but there are some downsides. The added weight the shifter issues and the like. Check out http://www.hasport.com they have a bolt in kit for this. Call and talk to their techs, they've aways been really helpful. They'll give you the skinny.
Old Dec 19, 2001 | 05:48 PM
4doorH22's Avatar
Default Re: h22a fit in? (HondaGuruTX)
I'm not sure, but I think that combination will only use 3 of the H22As 4 motor mounts. There have been many Civic/H22 hybrids though, so it certainly can be done. I also think it's impossable to keep A/C and power steering (if you care for those) without major fabrication.
Old Dec 19, 2001 | 09:53 PM
SiREF8's Avatar
Default Re: h22a fit in? (4doorH22)
Yeah it will fit in a Civic, but you will have little room in the engine bay. I have a friend who is getting an H22 in a Civic Hx right now. <U></U> http://www.intercrewautosalon.com
Old Dec 20, 2001 | 01:33 AM
D16Z6racing's Avatar
Default Re: h22a fit in? (SiREF8)
go with the b18. fits right in. by the time you pay for the h22 and install, you'll make out around the same price. yeah, 1.8 vs. 2.2, but 195hp(1.8) or 200hp(2.2). plus with the h22, you'll have more weight, more under steer, no ac, and no power steering. if those matter to you. an lsd tranny will help with the understeer, but it takes some great customizing ot get ac and ps back. if 5hp matters...h22 it. but if it don't and you want a lot less work...b18 it.
Old Dec 20, 2001 | 12:40 PM
Spade's Avatar
Default Re: h22a fit in? (buster13)
Buster......the whole point in the H22 is not the horsepower.......TORQUE!!!! it is always about torque.........
Old Dec 20, 2001 | 12:55 PM
Grimm's Avatar
hey thanks. I am just thinking really hard about swapping and I want to go for the best if i'm gonna spend that kinda money. I'm thinking the b18c-r then adding a turbo to that possibly. I just want to know everyones opinion on this cause I've never done anything like this nor do I know anyone who has. I figure go ***** out right. anyone with some other good ideas or helpful hints feel free to throw them my way.
this is what i was looking at
97+ B18C-R Engine
• 1800cc (1.8L) DOHC Vtec
• 197hp @ 8000 rpm
• 134 ft-lbs @ 7500 rpm
• 11.0 compression ratio.
• Hydro tranny type w/ LSD. $4850 US
Old Dec 20, 2001 | 01:27 PM
4doorH22's Avatar
Oh course I'm a big fan of the H22 to pull around my heavy car, but I know of two EG hybrids... one a H22A the other a B18C5. They're both putting down over 220 HP to the wheels and both run mid 12s.
Old Dec 20, 2001 | 03:21 PM
speedillusion's Avatar
New User
you know when you try to coast coming off the freeway?... you'll get my "drift"...
on an h22, there's a lot of understeer, your suspension also needs a lot of research when you do a swap likw this. just a thought.
boostedNOTHARDLY
Sep 26, 2017 05:16 AM
jordan_rael_420
Sep 8, 2010 10:52 AM
Ek9kidd
Jul 31, 2006 09:42 PM
euro-r-accord
Apr 17, 2004 09:52 PM
