turboed s2000's... are there many?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDS2K »</TD></TR><TR><TD CLASS="quote">I have a turbo s2k with 18 psi..... go with a INLINE PRO KIT</TD></TR></TABLE>
18 psi on a stock motor? no. not with 11:1. i was thinkin about the drag kit??
18 psi on a stock motor? no. not with 11:1. i was thinkin about the rev hard kit?
there's a ton of turboed s2ks..... and umm i heard the rev hard kit sucks.. heard it's missing a lot of parts....and as for the drag kit?? umm i didn't know drag had one for the S....
Hey Boosteds2k,
whats kind of setup are you running? and your running on a stock bottom end with just the headgasket??
and what kind of ems are you running?
thanks
thanks
we are in the process of building our owe turbo kit for the 04, i have see a few kits out there, nothing out here i like. we're going to build one with tubular manifold and gt 3037 turbo. i will post some pictures when we get it done.
I have the INLINE PRO Stage 2 kit...... with gt-35-61 turbo...3inch down pipe...3 inch exhaust (no cat) 1000cc injectors...255 fuel pump.... Aem Ems..Aem Wide band...Turbo Smart 35mm ultra-gate...Turbo Smart BOV...Turbo Smart Boost Controller..... Greddy turbo timer.. Clutch Master stage 4 clutch and fly wheel..GM 3 bar map sensor...InLine Pro Map defensor.. Ported and polished head..And 3mm head gasket......May be leaving out a few things... if so sorry.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTEDS2K »</TD></TR><TR><TD CLASS="quote">I have the INLINE PRO Stage 2 kit...... with gt-35-61 turbo...3inch down pipe...3 inch exhaust (no cat) 1000cc injectors...255 fuel pump.... Aem Ems..Aem Wide band...Turbo Smart 35mm ultra-gate...Turbo Smart BOV...Turbo Smart Boost Controller..... Greddy turbo timer.. Clutch Master stage 4 clutch and fly wheel..GM 3 bar map sensor...InLine Pro Map defensor.. Ported and polished head..And 3mm head gasket......May be leaving out a few things... if so sorry.......
how's the turbo treating you?? any problems yet?? i know that shaun had problems with leaks on his... and umm.. you know i think i met you once at a small meet at barnes and noble... i was the one parked next to you in the suzuka...
</TD></TR></TABLE>how's the turbo treating you?? any problems yet?? i know that shaun had problems with leaks on his... and umm.. you know i think i met you once at a small meet at barnes and noble... i was the one parked next to you in the suzuka...
12 lbs on basically stock internals. Has Darton sleeves and ARP head studs, that's it! Oh yeah, GT3540 turbo and 1700cc methanol squirting injectors controlled by an Autronic ECU. I love boost!
450+/- at the tires.
We have a kit for the AP1. So far we have done 4 and all are still running strong but running low boost though. 7 pounds and reaches full boost at 3500 rpm.
Duc
Duc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timg »</TD></TR><TR><TD CLASS="quote">I'm running the GT3037 right now on my 2004. It's an awesome turbo!
Tim</TD></TR></TABLE>
u have any pics? wut kind of engine management r u running if any.
I wonder how safe is running the 3mm headgasket from Inline kit. Its an awesome kit but how long can that headgasket last. ?? anyone know how reliable is that kit?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATF Kuk »</TD></TR><TR><TD CLASS="quote">
u have any pics? wut kind of engine management r u running if any.</TD></TR></TABLE>
Tons of pics. I have a couple on my cardomain site.
http://www.cardomain.com/memberpage/719379/2
If you're interested in more, PM me your e-mail and I can send you about 15 of them.
I'm running the 30-1012 AEM ECU.
Tim
Tim
