I have another question
Old Dec 19, 2001 | 10:54 AM
SoCal ITR's Avatar
Default I have another question
My guess is that people are tired of reading through 13 pages. So I'm posting this as a seperate topic. If I had found this iformation, then I wouldn't be posting this, and if I missed it, give me a heads-up. Thanks.
Okay, was the JDM 4-1 SS or Ceramic coated, and will that make a difference in power?
Old Dec 19, 2001 | 10:58 AM
HX_Guy's Avatar
Default Re: I have another question (SoCal ITR)
No, there is no reason why that would make a differance in power.
Old Dec 19, 2001 | 11:22 AM
Big Phat R's Avatar
Gas scavenging is affected by temperature changes. As the spent, very hot exhaust leaves the cylinder head it cools rapidly as it's heat is lost to the inner walls of the header. Ceramic coatings help to keep the heat within the lumen of the primary. But they can also cook the metal of the header primary as a result (i.e. cracking). Ceramic coatings are mainly intended to reduce underhood temperatures which decreases the wear and tear on the other parts of the motor (especially with forced induction) thereby increasing "performance". Ceramic coatings will also give headers more corrosion resistance if you drive your car in the wintertime. Someone correct me if I'm wrong here....
blurry454
Jun 23, 2009 09:40 AM
96-h22a1
Oct 25, 2008 02:00 AM
DARKTEG_
Aug 11, 2006 11:26 AM
B18_C3P0
Sep 25, 2002 11:10 AM
Milano95
Aug 17, 2001 11:25 AM
