EP3 + DC5R Rims..do I need spacers or no??
Old Oct 23, 2004 | 09:37 PM
Halo's Avatar
Default EP3 + DC5R Rims..do I need spacers or no??
From my understanding the DC5R rims are 17x7 with 60+mm offset, I believe all the usdm dc5's run a 45 offset, why such a big difference? My friends are saying I should run a 15mm spacer to get to 45 offset.. Are there any ill effects if I don't want to use a spacer and just run 60 offset? I plan on running the 225/45 Azenis..Thoughts? Oppinions?
Old Oct 23, 2004 | 09:57 PM
SIINSI's Avatar
Default Re: EP3 + DC5R Rims..do I need spacers or no?? (Halo)
Wow, that 60 offset doesn't sound right. Is it? I am going to be running 17x7.5 wheels on my EP3 with a +43 Offset. I would just slap the wheels on and see. If it looks funny or dosn't feel right, then get the spacers.
Miguel
Old Oct 23, 2004 | 11:13 PM
civicvtec1ps's Avatar
DC5R wheels offset is different than usdm rsx's due to brembo front brakes.
You will need spacer.
And 5 lugs swap if you have 02-03 ep3.
Old Oct 23, 2004 | 11:24 PM
Halo's Avatar
Default Re: EP3 + DC5R Rims..do I need spacers or no?? (civicvtec1ps)
what would happen if I just ran the wheels as is though without the spacers?
Old Oct 24, 2004 | 03:13 AM
ep3minivan's Avatar
for the EP, it won't fit unless you have spacers. for the RSX, the rear needs the spacers the most. if the rsx is low enoguh, the wheels will not fit in the rear unless you have spacers.
Type ARRR
Apr 6, 2010 09:04 AM
lif3tak3n
Jan 29, 2007 03:05 PM
Spork Sports
Aug 13, 2004 02:30 PM
dacaveman
Jan 1, 2004 07:25 PM
NW94RS
Dec 30, 2003 02:48 PM
