60mm offset
Old Dec 29, 2003 | 02:18 AM
NW94RS
Guest
Posts: n/a
Default 60mm offset
is there anyway that I can run a 60mm offset on a integra I understand that I will probably have to use spacers but thats fine as long as it doesn't look like a lowrider.
I know i've seen a ITR with rsx wheels and i'm pretty sure those use a 60mm offset.
any help is appreciated.
thanks,
SEAN
Old Dec 29, 2003 | 06:46 AM
MikeD's Avatar
New User
Default Re: 60mm offset (DC-2R)
I used 55mm wheels from a Prelude on my R and they fit fine except at full lock (like when doing a U-turn) where they would rub on the inside a little. I was also using 225 width tires, so that might have also contributed to the rubbing. A 10mm spacer would make 60mm offset wheels fit perfectly. Where you'd get 10mm spacers is another issue. Anything from a 7mm to a 15mm spacer would probably work fine.
Mike D.
Old Dec 29, 2003 | 07:41 AM
mstewar's Avatar
Default Re: 60mm offset (MikeD)
OEM wheel studs may not have enough tread sticking out to be safe with a 10mm spacer..
Old Dec 29, 2003 | 09:02 AM
sjracer's Avatar
USDM DC5 use a 45mm offset wheel. The JDM DC5-R uses a 55mm offset wheel because it has stock Brembo brakes. I have no idea where you heard the RSX uses a 60mm offset. There's no way it will clear the strut with a 60mm offset on a USDM DC5.
Old Dec 29, 2003 | 10:13 AM
NW94RS
Guest
Posts: n/a
Default Re: 60mm offset (sjracer)
will the wheels be popping out or will they look normal.
Old Dec 29, 2003 | 10:24 AM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R &raquo;</TD></TR><TR><TD CLASS="quote">will the wheels be popping out or will they look normal.</TD></TR></TABLE>
On both vehicles, RSX and DC2-R, a 60mm offset wheel will be tucked far into the wheel well if it was able to fit. A 60mm offset might be able to work on the DC5-R, but i guess it all depends on the wheel width also.
Old Dec 29, 2003 | 11:03 AM
NW94RS
Guest
Posts: n/a
so my wheel will be tucking in so a 60mm offset with a 10mm spacer will put the wheels at a normal look.
any help would be apreciated as i'm trying to buy these wheels this week.
can I comfortably use these on my dc2?
thanks
Old Dec 29, 2003 | 11:06 AM
Reid's Avatar
Global Moderator
What size are the wheels and what size tires will you be using?
Old Dec 29, 2003 | 11:17 AM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R &raquo;</TD></TR><TR><TD CLASS="quote">so my wheel will be tucking in so a 60mm offset with a 10mm spacer will put the wheels at a normal look.
thanks</TD></TR></TABLE>
You would have to ask an actual DC2 owner because i drive a RSX Type S. Will a 50mm offset wheel work in your situation? Well that would all depend on the wheel size and tire size you're looking into. Remember though, with a 10mm wheel spacer you will need longer wheel studs. The lugs won't have enough turns on the stock studs. Good luck.
Old Dec 29, 2003 | 11:45 AM
NW94RS
Guest
Posts: n/a
Default Re: 60mm offset (Reid)
the wheels are 16"s what size tires would you recomend.
Old Dec 29, 2003 | 11:47 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R &raquo;</TD></TR><TR><TD CLASS="quote">the wheels are 16"s what size tires would you recomend.</TD></TR></TABLE>
16 x ???
EDIT:
This is in regards to fitment on an ITR, correct?
If not, please post this in the Integra forum as the non-ITRs and ITRs use different offset wheels.
Old Dec 29, 2003 | 12:04 PM
NW94RS
Guest
Posts: n/a
I will check the width tonight
the car is a 94 rs with complete 5lug cinversion.
Old Dec 29, 2003 | 12:44 PM
Quang-StAR*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R &raquo;</TD></TR><TR><TD CLASS="quote">I will check the width tonight
sick car dude ! what kinda wheels are u trying to get sean, and answer your damn PM !
Old Dec 29, 2003 | 12:54 PM
Mario's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjracer &raquo;</TD></TR><TR><TD CLASS="quote">USDM DC5 use a 45mm offset wheel. The JDM DC5-R uses a 55mm offset wheel because it has stock Brembo brakes. I have no idea where you heard the RSX uses a 60mm offset. There's no way it will clear the strut with a 60mm offset on a USDM DC5.</TD></TR></TABLE>
3 problems...
DC5-R has a 60mm offset, so the person you corrected is right.
You said that it is because of the Brembo calipers, that the DC5-R has a higher offset than USDM DC5. But everything else the same (dimension wise), a lower offset will give you better spoke-to-caliper clearance. It will PUSH the outer face of the rim further out to the sides. So you're logic is backwards.
I am not a DC5 owner, yet I know the car better than you do. Lame.
Old Dec 29, 2003 | 12:59 PM
yoshi234's Avatar
I shoot brides
Default Re: 60mm offset (Mario)
mario is ri...
DC5R wheel = +60mm offset
yoshi - who is sitting next to four of them ri now
Old Dec 29, 2003 | 01:05 PM
NW94RS
Guest
Posts: n/a
Default Re: 60mm offset (yoshi234)
so do you guys think I could use them.
Old Dec 29, 2003 | 01:09 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario &raquo;</TD></TR><TR><TD CLASS="quote">
3 problems...
Ok smart guy. First off, the Brembo hub pushes further out (towards the outer fender) further then the Type S hub. Therefore they use a 55mm offset wheel to fit into the fender well, not to clear the Brembo calipers. When did i ever say they use a high offset wheel to clear the caliper? I said they use the high offset wheel because of the Brembo brakes; not because it's used to specificly CLEAR the caliper.
(Second, there are numerous DC5 owners at clubrsx WHO HAVE the JDM DC5-R wheel and have stated that it's a 55mm offset, not 60. Go check it out yourself.) Edit: I take this part back only because i was mislead by other members.
Looks like you don't understand simple english. (Reading comprehension owns you.) It's ok though, but don't take your frustrations out on me. I was only try to help this guy out.
Old Dec 29, 2003 | 01:11 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yoshi234 &raquo;</TD></TR><TR><TD CLASS="quote">mario is ri...
yoshi - who is sitting next to four of them ri now </TD></TR></TABLE>
Well since you have them in front of you, i believe you. The people over at clubrsx is wrong. Thanks for the info yoshi.
Old Dec 29, 2003 | 01:17 PM
NW94RS
Guest
Posts: n/a
hey you guys mind not starting a flame war in my post.
Old Dec 29, 2003 | 01:22 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R &raquo;</TD></TR><TR><TD CLASS="quote">hey you guys mind not starting a flame war in my post.</TD></TR></TABLE>
Sorry. Like i said earlier, i was only trying to help you out. Looks like it's "Mario" who wants to attack other people with comments like, "I am not a DC5 owner, yet I know the car better than you do. Lame." Tell me that little comment at the end was called for.
Old Dec 29, 2003 | 02:56 PM
yoshi234's Avatar
I shoot brides
would it help j00 if I put the dc5r wheels on 234?
yshi - who's been wanting to do this but other chit keep coming up
Old Dec 29, 2003 | 06:06 PM
NW94RS
Guest
Posts: n/a
yes what did you have todo to fit them.
Old Dec 29, 2003 | 11:36 PM
Mario's Avatar
I was only try to help this guy out.</TD></TR></TABLE>
...with misleading second-hand information.
It's only natural that you get defensive, after being proven wrong in a public forum. Sorry about that.
Getting back on topic, in the odd chance that Yoshi doesn't come through. I'll also try installing the DC5R rim onto my 98spec JDM 5 lugs.
Old Dec 29, 2003 | 11:51 PM
sjracer's Avatar
That's real funny. That coming from a guy who was proven wrong by my previous post up above. If i remember correctly, you were trying to prove something about me saying they use a higher offset wheel on the DC5-R to clear the brembo caliper? Wait, that's right; I said no such thing in the first place. Don't act like you know more about the DC5 chassis just because you're installing DC5-R wheels on your DC2.
PS: I was wrong about the offset and I admitted it. Now who's the bigger man?
On topic: Yoshi, are you going to be using wheel spacers? Isn't a 60mm offset a little too high of an offset to be using on your DC2-R?
EDIT: I'm just adding these quotes so you won't keep on rambling about something else...
Modified by sjracer at 1:08 AM 12/30/2003
Old Dec 30, 2003 | 02:48 PM
yoshi234's Avatar
I shoot brides
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sjracer &raquo;</TD></TR><TR><TD CLASS="quote">On topic: Yoshi, are you going to be using wheel spacers? Isn't a 60mm offset a little too high of an offset to be using on your DC2-R?</TD></TR></TABLE>
no, since i'm only doing it to show what it'd look like. besides, my spacers are currently being used on another w/ 17" MF10s
JDM978
Jan 19, 2006 08:07 PM
Belle Naught
Aug 30, 2005 12:18 PM
Halo
Oct 24, 2004 03:13 AM
sk898
Dec 18, 2002 02:22 PM
