1989 Accord, manual transmisson question
Old Oct 23, 2004 | 08:17 PM
bearcat's Avatar
Default 1989 Accord, manual transmisson question
I am changing the manual transmission in my son's 1989 Accord, (something blew apart inside and even cracked the case), and I need to know somthing.
Are 2 lines that I disconnected next to the speedometer cable cooling lines? The reason I ask is because automatic transmission fluid came out of those lines. With this being a manual tranny, I was just a bit confused.
If thats what they are, then that could be the reason this tranny blew apart, huh?
Old Oct 23, 2004 | 09:04 PM
v4lu3s's Avatar
RTFM
more than likely they are for speed sensitive power steering. and hte stuff that came out was power steering fluid.
Old Oct 24, 2004 | 12:21 AM
89_LXi's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">more than likely they are for speed sensitive power steering. and hte stuff that came out was power steering fluid. </TD></TR></TABLE>
Yep... that would be correct. The VSS doubles as the oil pump for the variable assist power steering system, and the fluid you see is p/s fluid. Don't forget to top that off when you're all done, with "Honda" power steering fluid only
krisiks
Apr 18, 2015 05:26 AM
kayONE
Mar 13, 2013 11:42 AM
Deej23
Mar 17, 2012 05:37 PM
EM2junkIE
Honda Civic (2001 - 2005)
Apr 16, 2008 09:46 PM
seelyd
Dec 13, 2006 02:49 AM
