Help Me build my first engine - b20z Vtec
Old Dec 19, 2001 | 10:15 AM
azn_outlaw's Avatar
New User
Default Help Me build my first engine - b20z Vtec
What is needed to make the CRV b20z block, have VTEC?
I want it to be N/A, but also it has to be a reliable street driver and its daily driven
This is what I want the engine to be consisted of:
b20z block
Skunk2 intake manifold
b16 head (VTEC head)
ITR cams with adjustable cam gear
70 mm throttle body
Comptech ICE box
What is needed to be done to incorporate VTEC?
With pistons, which do I use and which rods do I use as well?
Can I still use a b-series ECU such as a GSR or ITR?
Octane wise, what will I need use?
Fuel Pump and Oil Pump --> go with stock or go aftermarket?
Transmission, okay which one, has to be JDM cause of the LSD? (I have in mind b16 tranny with LS final gear)?
Is the b20z VTEC a high reving combination?
What else am I missing or what else do I need so this thing is reliable and makes my Civic a great daily driver?
Can this be built, without spending a whole load of money budget is set at 5800?
Thanks
Old Dec 19, 2001 | 10:19 AM
chi1874436's Avatar
Default Re: Help Me build my first engine - b20z Vtec (azn_outlaw)
go to http://www.c-speedracing.com. then go to the HOW-TO'S and there's your swap.
Old Dec 15, 2008 | 11:36 AM
b18c1ej8's Avatar
rod bolts, head studs, get tuned because there is no oem ecu for ls/b20 vtecs and search
1997-Civic-cx
Jan 10, 2016 01:25 PM
foxracing_23
Nov 3, 2007 06:10 PM
crxhf19
Apr 15, 2005 10:53 AM
cubancrx
Aug 30, 2004 11:59 AM
