drain location on ek radiator
it's at the bottom, behind the plastic splashguard, but there should be a hole cut out of the splashguard and a white plug behind it. loosen the plug to drain, dont have to remove
04 member :shakes head:
some will say that this is not a jacking point, but i usually jack the front up by the knub on the radiator support.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Or you can run it real hot then pop the cap and run for your life . But I like DOHC4life's idea much better.</TD></TR></TABLE>
lol, I've seen it done. Not to hard, but you still have to drain it from the bottom.
braass91
Nov 24, 2012 02:04 PM
