Honda S2000 Honda S2000
Lightweight Flywheels
Old Oct 23, 2004 | 01:33 PM
JdmLude04's Avatar
Default Lightweight Flywheels
Lightweight flywheels worth it for a s2k?? i know the stock one is pretty light, just wondering if the spoon or toda helped free up anymore horsepower to the wheels?? any info appreciated.
Old Oct 23, 2004 | 02:23 PM
ImportSport's Avatar
Most people prefer the Comptech flywheel because it has less dynamic parts that may lead to damage. They are all good products though.
There are some pretty big threads about this over at s2ki.com I would do a search and get some info. Generally there is slightly improved throttle response which makes rev matching between shifts a bit easier.
Old Oct 24, 2004 | 08:21 PM
papa5murf's Avatar
Default Re: (ImportSport)
go with the comptech.... lots of praise on them...and they work well with a act clutch and the stock presure plate... it's a rather cost effective setup...
Old Oct 25, 2004 | 05:35 AM
profpin's Avatar
Default Re: (03s2kblue)
im running toda flywheel and act clutch kit.. the throttle response is much more snappy.. revmatching is now more fun..
Old Oct 25, 2004 | 07:07 AM
Ahhvtec1's Avatar
Default Re: (profpin)
Comptec in my book, easier to come by...
Old Oct 25, 2004 | 09:34 AM
Default Re: (Ahhvtec1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">go with the comptech.... lots of praise on them...and they work well with a act clutch and the stock presure plate... it's a rather cost effective setup... </TD></TR></TABLE>
I think this poster was switched around. The common package is OEM clutch disk, ACT pressure plate and Comptech fly wheel. This is also the package being sold by Hardtopguy.
The old clutch problem was due to spring tension on the clutch disk leading to decel rattle. The new oem disks are generally good quality for an NA application.
Old Oct 25, 2004 | 01:23 PM
L8NightDrifter's Avatar
Default Re: Lightweight Flywheels (JdmLude04)
Old Oct 26, 2004 | 09:47 PM
AJ PwR's Avatar
I am running Spoon and the throttle response is a bit sharper and revs are faster.
Old Oct 27, 2004 | 07:11 AM
Eri_S2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportSport &raquo;</TD></TR><TR><TD CLASS="quote">
The old clutch problem was due to spring tension on the clutch disk leading to decel rattle. The new oem disks are generally good quality for an NA application.</TD></TR></TABLE>
So you are telling me the OEM CLutch SUCKS!??
maxpierre
Honda S2000
11
Feb 11, 2007 03:23 PM
AW
Mar 12, 2004 06:08 PM
Mr.Integra
Jan 22, 2004 06:24 AM
rated_r
Nov 25, 2002 05:01 AM
Stifler
Nov 9, 2002 06:59 AM
