5th gear grinds..new shift fork? syncro? help please
Old Oct 23, 2004 | 12:50 PM
brandond's Avatar
B A N N E D
Default 5th gear grinds..new shift fork? syncro? help please
wuts up guys i just put this lsd tranny in my h22 eg and when ever i put it in 5th it grinds then pops right out once i get on the gas.....do i need a new shift fork?,syncro? and my otehr question is where can i buy those 2 parts from, and how much will it cost if u know that would be great thank you!
Old Oct 23, 2004 | 02:12 PM
Carbon_Lude98's Avatar
Default Re: 5th gear grinds..new shift fork? syncro? help please (brandond)
mine dose to but only in a higher rmp..like 4k up...if i shift to 5th at like 3k its fine.
Old Oct 23, 2004 | 03:49 PM
h22 civic's Avatar
Default Re: 5th gear grinds..new shift fork? syncro? help please (Carbon_Lude98)
i would buy a 5th gear(FOR THE MAIN SHAFT ONLY) and sleeve set,its bout 175 for everything if ya got a hook up most likely the syncro ring, slider, hub, and gear teeth are shot change and you'll be AOK
Old Oct 23, 2004 | 03:59 PM
PreludePhill's Avatar
i had the same problem when i first got my car, shift fork was bad.
Old Oct 23, 2004 | 11:33 PM
Monkey Fing a Coconut's Avatar
Default Re: (N2oH22)
thats not the normal 5th gear grind, if u just bought the swap from hmotors or the like i would see if they would swap the tranny, otherwise it's definately the syncro and its at least $175 for the parts and at least another $200 for someone to open the tranny, plus another $200 or so to get the tranny off....if u have to open it though u may wanna just go ahead and get the 3rd gear stuff as well since those are almost always the first to go...h22 tranny's dont like 2-3 shift at 7k very much
u could try new tranny fluid, u need 3 quarts at $5 a bottle, $15 and it may do somethin for ya
Old Oct 24, 2004 | 05:18 AM
StuntMonkeh's Avatar
Had the same problem on mine. Eventually you will be unable to select reverse gear.
Get the 5th gear syncro replaced and the problem will be solved.
Old Oct 24, 2004 | 08:21 AM
lunarcry's Avatar
[QUOTE= where can i buy those 2 parts from, and how much will it cost if u know that would be great thank you![/QUOTE]
http://www.hondaautomotiveparts.com/home.htm
Old Oct 24, 2004 | 08:44 AM
brandond's Avatar
B A N N E D
Default Re: (twistedbydezign)
yeah im taking the tranny off my myself thats not that big of a deal i jsut need to find someone to open it up and put teh parts in there i need
Old Oct 24, 2004 | 12:35 PM
satan_srv's Avatar
Default Re: (brandond)
try double clutching...I used to do that to avoid it...saved me taking it apart
blankslat5
Nov 10, 2008 04:27 PM
92EG8
Apr 22, 2007 12:49 PM
sterjess
Jun 22, 2005 07:37 PM
snatch
Jul 1, 2004 07:01 PM
vtekthis
Feb 8, 2004 02:47 PM
