Help car wont start!
Old Oct 23, 2004 | 11:02 AM
Ty.'s Avatar
Ty.
Default Help car wont start!
Ok here is what is going on. a few days ago after work i got in my car and turned the key over and my car did not start. after a few times turning it i looked around to see if i had left a light on or anything. nothing was left on so i turned it one more time and it started perfect. WTF.
then for about a week it ran perfect starting everytime till yesterday. car just wouldnt start. i kept turning and finally gave up and push started my car. next time i turned it off it started right up and the next 3 times it worked great. then it did it again last night it didnt start the first few times i tried but then it started right up.
Now its in my garage and i have been looking for any loose connections and i cant see any. i have also looked at the main relay and it all is connected fine. i do have a turbo timer in there but i dont see how that is the problem it has been there for over a year.
sounds the car makes are the fuel pump turns on. all electrical still works. no clicking except one small click when i turn it over, but not repetitive like when battery is dead.
please help. i have searched and there are a few problems similar to this but they arent helping me.
Old Oct 23, 2004 | 11:16 AM
Archidictus's Avatar
Unceasing Measure
Default Re: Help car wont start! (BLACKEG2)
I know it sounds simple but have you checked your battery terminal connections? I had a problem very similar to this earlier this past summer and it was just a positive ring clamp that would jostle loose every once in a while.
I like to think that some problems still have simple solutions . Good luck.
Old Oct 23, 2004 | 12:10 PM
Ty.'s Avatar
Ty.
Default Re: Help car wont start! (Archidictus)
battery connections are fine and tight.
Old Oct 23, 2004 | 12:53 PM
Ty.'s Avatar
Ty.
also car is 94 del sol with factory b16a3. It never did this until i got my alarm installed. but they never hooked up the engine cut part of the alarm so im not sure if that could have done anything!
Old Oct 24, 2004 | 06:58 PM
Ty.'s Avatar
Ty.
still cant figure it out!
Old Oct 24, 2004 | 07:01 PM
EH3Kid85's Avatar
Are you making sure the clutch is pushed in?
j/k
I dunno man...is your starter clicking? Or do you just turn the key and hear nothing?
Old Oct 24, 2004 | 07:07 PM
Ty.'s Avatar
Ty.
Default Re: Help car wont start! (EH3Kid85)
well hte first thime i thought that maybe it didnt start becasue of the clutch but i know i am pushing it in now.
i hear all the normal things when i turn the key over all except the car starting. no extra clicks like battery is dead or anything!
Old Oct 24, 2004 | 08:23 PM
elmo's Avatar
25 Year Member
If all you hear is one click, check for power to the starter. If you get power there, then your starter solenoid is bad. Replace the starter. If you don't get power there when cranking, see if you are getting power at your ignition switch at the blk/wht wire when cranking.
If there is no power there, then you may have a bad ignition switch.
Most likey you have a bad starter solenoid. Good luck.
Old Oct 24, 2004 | 09:18 PM
2+2Door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLACKEG2 &raquo;</TD></TR><TR><TD CLASS="quote">also car is 94 del sol with factory b16a3. It never did this until i got my alarm installed. but they never hooked up the engine cut part of the alarm so im not sure if that could have done anything!</TD></TR></TABLE>
does your car keep turning over but it doesnt run???
i have the same exact problem for my sisters car. It only happened yesterday after i had a viper alarm system installed.
Old Oct 24, 2004 | 09:57 PM
Ty.'s Avatar
Ty.
Default Re: Help car wont start! (HeterHsan)
thats the same alarm i got installed. viper. but they said they didnt mess with anything that would be part of the ignition. but thats wierd.
buzlink
13
Jun 6, 2010 12:16 PM
explosive
Aug 21, 2009 04:30 AM
Its me DUB
14
May 13, 2005 09:40 AM
93egsi
20
Aug 26, 2003 02:54 AM
TurboedGSR
Sep 18, 2002 05:23 PM
