Im stumped and Im asking for help
Old Oct 23, 2004 | 06:13 AM
CRX_Control's Avatar
Default Im stumped and Im asking for help
This is my problem, crx 88 hf with a d16y8 put in , p28 , conversionharness from blown90hatch,and finally..a obd2 distributor stock for the y8, my problem is that i cant get my car to start because of the wiring of the distributor.It has 8 wires running from a plug while my 88 hf harness gots 9,iv tried searching but i came up with nothing.I really dont wanna give up on this project car, but i cant seem to find anyone that whould help me. This is what i have wired for now .
obd0---------------obd2
blk/yellow---------blk/yellow
Blue----------------Yellow/green
orange/blue-------orange/blue
white/blue---------white/blue
and these are the ones i got unwired
obd0(unwired)-white(by self),white(next to two wires),blue/green,blue/yellow,orange.
obd2 dizzy(unpluged)-grey,white,light blue,orange.
If anyone gots any idea where thos left over wires goes please tell me, or send me some bs wiring so at least i can try that out . Thanks Eric
Old Oct 23, 2004 | 06:21 AM
hatchblack's Avatar
Default Re: Im stumped and Im asking for help (CRX_Control)
not sure where the 9 wires come from, cause there should only be 7 going to the distributor, unless you are mixing up the other plug with the wires too. i believe that smaller plug only has two wires. anyway, this is all i can help you with for the moment - i don't have the obdII wiring, and the obd0 wiring is from memory. the thicker white is power, the cylinder sensor should be an orange wire and a smaller white wire, the crank sensor are the blue/green and blue/yellow wires, and the TDC sensor would be the white/blue and orange/blue wires. the black/yellow and the blue wire goes to the second, smaller plug, which i'm not sure what they do, i don't remember. So, i can tell you that you are already matching the wrong wires together. keep the black/yellow and blue wires out of the picture for the moment and just work on getting the other wires hooked up to where they should be. find someone who has a diagram of the obdII distributor and you should be able to match the wires correctly. good luck.
Old Oct 23, 2004 | 06:34 AM
Default Re: Im stumped and Im asking for help (hatchblack)
forsome odd reason there is no other plug with my dizzy, its just one plug with 8 wires.
Old Oct 23, 2004 | 02:44 PM
hatchback_al's Avatar
you do not have a y8 distributor then. I just added obd1 plugs to my y8 distributor for my y8 motor and obd1 swap. there is 9 wires and 2 plugs. 7 wires for the big plug, and the black and blue yellow wires are on the smaller plug. Im sorry but if you only have 8 then you are missing a wire or dont have the right distributor.
everythingwentblack
May 7, 2006 03:20 PM
racin_fool
Apr 30, 2006 01:42 PM
3s0n3
Apr 1, 2006 04:51 AM
xsuperxsonx
Dec 25, 2005 02:00 PM
gocivicgo
May 16, 2003 01:45 PM
