Hot... so very hot
Old Oct 23, 2004 | 01:48 AM
Shinta's Avatar
Default Hot... so very hot
Does anyone know why my cabin is so hot... particularly from the gear box area?
I have done a H22a swap and definately dont have an overheating problem.
And since doing the swap my engine light has come on a stays on. Does anyone know why?
Thanks
Old Oct 23, 2004 | 03:52 AM
FSR-Jones's Avatar
Default Re: Hot... so very hot (Shinta)
Turn your heater off! Haha jk. No idea man... I just had to say it.
Old Oct 23, 2004 | 07:23 AM
screwballz's Avatar
exhaust heat/fumes is probably coming up through an opening around your shifter. had the same problem when i did auto to manual swap without covering up the hole.
Old Oct 23, 2004 | 08:03 AM
BauleyCivic's Avatar
Risky Business
Default Re: Hot... so very hot (screwballz)
the exhaust is hot, theres a hole where your shifter is...put two and two together...
About the CEL...pull the code ala the thread stickied at the top of the page and find out whats wrong.
Old Oct 23, 2004 | 09:07 AM
vtec69's Avatar
you probally dont have any heat shields on the exhaust around the area where the shifter is causeing the inside to be hot
Old Oct 23, 2004 | 09:10 AM
unknown0001's Avatar
Default Re: Hot... so very hot (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">you probally dont have any heat shields on the exhaust around the area where the shifter is causeing the inside to be hot</TD></TR></TABLE>
My first guess
Old Oct 23, 2004 | 09:43 AM
Castor's Avatar
Default Re: Hot... so very hot (Mr.RHTuner)
Yeah my car came without the heat shields, when I drive to california, the floor along the exhaust is almost hot to the touch. yikes.
Old Oct 23, 2004 | 10:07 AM
Deemeetree's Avatar
Electrician
Roll your windows down or turn the A/C on.
Old Oct 23, 2004 | 10:17 AM
rodrez.'s Avatar
Not sure what car you have, but with an H22 swap, there's some trimming of the shifter area to fit everything properly in most cases. Since there's no factory trim to close the gap, yours probably allows heat to pass through into the cabin.
Old Oct 23, 2004 | 04:34 PM
Shinta's Avatar
Default Re: Hot... so very hot (Rodrez-O-lantern)
THanks guys... This seems to be exactly the problem
Old Oct 23, 2004 | 04:38 PM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shinta &raquo;</TD></TR><TR><TD CLASS="quote">THanks guys... This seems to be exactly the problem</TD></TR></TABLE>
Yes, this was also my problem in my Integra after I did the 5-speed conversion. I just welded/riveted some sheetmetal in that area and everything was fine.
Old Oct 23, 2004 | 04:39 PM
=GAME='s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodrez-O-lantern &raquo;</TD></TR><TR><TD CLASS="quote">Not sure what car you have, but with an H22 swap, there's some trimming of the shifter area to fit everything properly in most cases. Since there's no factory trim to close the gap, yours probably allows heat to pass through into the cabin. </TD></TR></TABLE>
very true.
you need to cover/seal the area where the old shifter was and also cover up the hole where you cut to fit the 2 shifter cables.
my cabin was also hot so i welded some sheet metal over the open areas.
as for the CEL, is it affecting the car at all? i have a CEL that stays on and its from code 12 which is the EGR. check the code and see what it reads.
Old Oct 23, 2004 | 04:42 PM
99CivicExCoupe's Avatar
Default Re: Hot... so very hot (=GAMEOVER=)
definitely trim for shifter. i installed short shifter and forgot to plug that thing back into place and i always feel the heat by my e-brake now
Old Oct 23, 2004 | 09:29 PM
dozerbro95's Avatar
hey how much did that cost? im hoping on doing that to my 95 civic DX
Old Oct 23, 2004 | 09:35 PM
Redline96LX's Avatar
* B A N N E D *
May I STRONGLY reccomend that a heat shield there or any plugs be sprayed with a enamel based cermaic spraypaint? They DO reduce thermal heat transfer, I can vouch for this, Sprayed my Short Ram Intake, and after driving for a while, sprayed versus shiny aluminum, its touchable after driving. If you spray the metal thats blocking the heat, this should help. Got mine at walmart for like 5$.
Old Oct 23, 2004 | 09:36 PM
vtec69's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Roll your windows down or turn the A/C on.</TD></TR></TABLE>
what is this thing you call A/C????
Old Oct 23, 2004 | 11:32 PM
civtegra_hybrid's Avatar
Default Re: (Dimi)
that **** don't have a/c, it has an H22 lol (won't fit)
Old Oct 24, 2004 | 03:12 AM
Alstare's Avatar
Default Re: (civtegra_hybrid)
Yes it will along with PS and Turbo so let's not get the hearsay rumors flying like usual...
boomersz
Mar 19, 2007 10:46 AM
mr poo
29
Jul 24, 2006 01:09 PM
xkhalil333x
Sep 9, 2003 02:07 PM
bluemex
Aug 24, 2003 02:20 PM
TwistedSI
14
Apr 18, 2003 07:08 AM
