Oil change what should I do
Old Oct 23, 2004 | 12:33 AM
DVS Luder's Avatar
Default Oil change what should I do
My question is I got my car about 1 1/2 to 2 weeks ago and when I check the oil dip stick, the amount of oil is a tiny bit below the middle of the two dots. I hear a lot about these h22s burning oil...so If I add more oil, what kind of oil should I put when I don't even know whats in it right now? I just want to add a little cuz someone from here (HT) told me to fill it up to the 2nd dot. If its non synthetic would it be safe just to add a tiny bit of whatever oil I choose(Royal Purple I prefer) cuz IM not getting my oil changed til next week or so...or should I just wait (I know my question is stupid), but if I do wait maybe its unsafe cuz my oil level is getting on low side?
btw it has about 62k miles
Old Oct 23, 2004 | 01:45 AM
vtec92lude's Avatar
Default Re: Oil change what should I do (DVS Luder)
I would recomend that you just keep a close eye on the level and not worry about it till you do the oil change.
But if you are that worried do an oil change now.
Good Luck
Old Oct 23, 2004 | 01:57 AM
@ries's Avatar
ok seriously... if you don't know what kind of oil they put in there to begin with then you should be bent over with no vasoline. if your oil is going to be changed next week then just put some 10-w30 in there and call it a day. no need to be so picky when you're going to change the oil soon.
Old Oct 23, 2004 | 06:18 AM
preludeez's Avatar
Default Re: Oil change what should I do (@ries)
if you're that worried - just change it now - then you'll know whats in there for sure - why wait a week?
Old Oct 23, 2004 | 10:55 AM
Carbon_Lude98's Avatar
Default Re: Oil change what should I do (preludeez)
i just add in mine..i add a quart about every 1500 miles.
Old Oct 23, 2004 | 06:07 PM
equinox's Avatar
you have enough oil, don't sweat it.
I would think you would be able to go for another couple weeks without any problems. Anyways if your low on oil, the oil light on your dash will light up.
Old Oct 23, 2004 | 07:27 PM
Default Re: Oil change what should I do (lude_roller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_roller &raquo;</TD></TR><TR><TD CLASS="quote">you have enough oil, don't sweat it.
I would think you would be able to go for another couple weeks without any problems. Anyways if your low on oil, the oil light on your dash will light up.</TD></TR></TABLE>
thats bad
Old Oct 24, 2004 | 09:32 AM
UA6 BALLER STATUS's Avatar
I dunno about that, people say that once the oil light turns on its too late and most likely you'll **** up something.
Old Oct 24, 2004 | 10:57 AM
civicgsr19's Avatar
Default Re: Oil change what should I do (Carbon_Lude98)
Yea dont do this, these a reason that oil light is called an"idiot light".
Old Oct 24, 2004 | 11:02 AM
Two_K Si's Avatar
Go ride a bicycle, you suck at cars
Old Oct 24, 2004 | 11:04 AM
DVS Luder's Avatar
Default Re: Oil change what should I do (Two_K Si)
and you suck dick
Old Oct 24, 2004 | 11:08 AM
DVS Luder's Avatar
Also I wasn't asking about the oil lighting up...main question was how bad would it be to add a lil bit of royal purle to the car, a car I just got so IM not sure what kind oil is in it right now!
Old Oct 24, 2004 | 11:13 AM
Two_K Si's Avatar
Mixing two brands of oil isn't going to **** up your engine dumbass...
Old Oct 24, 2004 | 11:18 AM
fastfu's Avatar
there is no reason why you can't just top it up.
the people on here should realise that we all had to start somewhere and we were all newbs hondas at one point.
Old Oct 24, 2004 | 11:19 AM
DVS Luder's Avatar
OK, even if its non synthetic mixed with a lil synthetic? Who are you to call other people you truly don't know a dumbass..that is why IM here at HT to ask, just to be sure. Im suprised your at 100% status, and don't mention the dick suckin part cuz you started it all.
Old Oct 24, 2004 | 11:21 AM
Jagan'92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVS Luder &raquo;</TD></TR><TR><TD CLASS="quote">the amount of oil is a tiny bit below the middle of the two dots. </TD></TR></TABLE>
your car has 4.5 or so quarts of oil. there is one quart difference between the two dots. you are low half a quart, top it off and forget about it. then change your oil when you planned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVS Luder &raquo;</TD></TR><TR><TD CLASS="quote">I know my question is stupid</TD></TR></TABLE>
So do we. You got your answers, now quit whining and follow them. If you're that worried about it - don't add any and just change your oil.
Old Oct 24, 2004 | 01:55 PM
mattmw88's Avatar
Default Re: Oil change what should I do (Jagan'92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DVS Luder &raquo;</TD></TR><TR><TD CLASS="quote">My question is I got my car about 1 1/2 to 2 weeks ago </TD></TR></TABLE>
so for all those ***-hats who can't read, the reason he doesn't know is because he just bought the car!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Two_K Si &raquo;</TD></TR><TR><TD CLASS="quote">Mixing two brands of oil isn't going to **** up your engine dumbass...</TD></TR></TABLE>
yes, mixing two kinds of oil CAN **** your engine up, if it was non-synthetic, and your switching to synthetic- (since your just adding a little bit it should be fine).
If I were you I'd find some sythetic blend, top off the oil and then from now on I'd use a synthetic blend, not a full syn.
BTW when the oil light comes on that means that there is air that is getting pushed through your oil pump... doesn't sound too healthy to me
Oh, and I'm a LUBE TECH, so respect my authorit-a-y (cartmen)
vinuneuro
Mar 15, 2005 04:41 PM
digitalayon
Mar 13, 2005 07:55 AM
matix
Apr 18, 2004 09:32 AM
blkbeast
May 28, 2003 10:48 PM
tensai717
Dec 9, 2001 03:49 PM
