b18c1 crx done....Overheating issues
Old Oct 22, 2004 | 09:43 PM
spcrxracer's Avatar
Default b18c1 crx done....Overheating issues
OK my swap is done but let me clue you in. I took the b18c1 gsr out of my crx dx, and moved it over to the new si i bought. IN the DX the motor ran mint! but now in the Si, it runs mint untill i go drive it for 10-20 min(under normal conditions-- i dont take it past 4k RPM). Then the temp gauge starts to move way up towards hot.
When I am stopped, the temp. needle slowly starts to return to normal.
I am not leaking coolant, i am not burning coolant, and there are no loose hoses to my knowledge. I also have a C&R radiator with FAL fan. I am pretty sure it's not the thremostat...any ideas???
Old Oct 22, 2004 | 10:03 PM
mrspeaker's Avatar
Default Re: b18c1 crx done....Overheating issues (spcrxracer)
Is it overheating only when at a stop or in slow moving traffic..??
Old Oct 22, 2004 | 10:06 PM
crxforum's Avatar
Default Re: b18c1 crx done....Overheating issues (Mrspeaker)
When my CRX was overheating it was from a leak in the rad. I know you said that wasnt the problem but that is what my problem was. The thermostat might be malfunctioning, but since it worked in the DX that shouldnt just happed for no apparent reason.
Are you throwing any codes or anything?
CRX Forum
Old Oct 22, 2004 | 10:13 PM
bossman032's Avatar
Default Re: b18c1 crx done....Overheating issues (crxforum)
dude ur fan is not probaly working.
cause the way they are wired are different.
Old Oct 22, 2004 | 10:23 PM
crxforum's Avatar
Default Re: b18c1 crx done....Overheating issues (bossman032)
I dont think that it would be the fan. It shouldnt over heat to the point of causing concern after 10 min. I drove my CRX with about 1/5 of coolant in it for 30 min before I noticed a problem. 10 min is way too soon for just the fan not to work especially if he is not leaking coolant.
But I could be wrong. Im not saying you are wrong I just disagree.
CRX Forum
Old Oct 22, 2004 | 10:45 PM
ef8 h0!'s Avatar
make sure no leadks, check the fan and fan switch conntections.
Old Oct 22, 2004 | 10:49 PM
bossman032's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxforum &raquo;</TD></TR><TR><TD CLASS="quote">I dont think that it would be the fan. It shouldnt over heat to the point of causing concern after 10 min. I drove my CRX with about 1/5 of coolant in it for 30 min before I noticed a problem. 10 min is way too soon for just the fan not to work especially if he is not leaking coolant.
CRX Forum</TD></TR></TABLE>
make sure your fan is working!! looks like your case get it check out.
Old Oct 23, 2004 | 05:46 AM
Big Bang's Avatar
head gasket?
Old Oct 23, 2004 | 09:59 AM
VtecKiDD's Avatar
Default Re: b18c1 crx done....Overheating issues (The Converted)
bleed it , then make sure the fan is working. my gsr had to be wired in different to get the fan to run
Old Oct 23, 2004 | 10:17 AM
integranator's Avatar
My friend has the same problems in his b18c1 swapped ef hatch. The doesnt kick on when it gets to hot. I would be willing to bet that this is your problem.
Old Oct 23, 2004 | 11:48 AM
301am's Avatar
this happened on my friends turbo gsr...it ended up being the thermostat was stuck shut so he went and bought a new one and it worked.
Old Oct 23, 2004 | 01:17 PM
Rywire's Avatar
Default Re: (301am)
I didnt have to wire my fan any diff... but I would check that, your thermostat, and bleed that thing man!!!
Ryan
Old Oct 23, 2004 | 03:06 PM
crxgsr91's Avatar
Default Re: (integranator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integranator &raquo;</TD></TR><TR><TD CLASS="quote">My friend has the same problems in his b18c1 swapped ef hatch. The doesnt kick on when it gets to hot. I would be willing to bet that this is your problem.</TD></TR></TABLE>
Mine also, I wired the fan to a switched power source also I upgraded the radiator to an integra one so even when the fan was not running it still did not overheat.
Old Oct 23, 2004 | 03:12 PM
HamiltonRex's Avatar
Start it, let it warm up till the gauge is about 1/3 of the way. Dont let it go past. Feel your upper rad hose. It should be hot. Feel your lower. It should be hot. They both should look "full". If the bottom is cold or is empty your thermostat isnt opening.
Old Oct 23, 2004 | 06:58 PM
Stefndogg's Avatar
prob the fan imo
Old Oct 23, 2004 | 07:24 PM
crexer's Avatar
Default Re: b18c1 crx done....Overheating issues (Stefndogg)
I went for over a year without a fan at all in my car, and I had a full size oem crx radiator. I only overheated 1 time being stuck in traffic for a few hours. Since then i wired up my own fan switch and I only use it when stuck in traffic for a while. I dont think its your fan. Replace your thermostat its only a few bucks anyhow and its cheap maintenance.
Old Oct 24, 2004 | 07:56 AM
Wes V's Avatar
Default Re: b18c1 crx done....Overheating issues (crexer)
Logic (not always correct) says that it's something that went wrong with the new installation and it isn't the engine.
I'd recommend that you disconnect the electrical connector that goes to the sensor that turns on the fan. With the ignition turned on (engine not running), you should be able to ground the terminal and the fan should come on. If it doesn't, then there is some problem with the wiring.
Wes
Old Nov 3, 2004 | 12:20 PM
spcrxracer's Avatar
Default Re: b18c1 crx done....Overheating issues (Wes V)
Alright i finally had some time off school to check this stuff out and here's what i found:
1) There was a small leak, but it was because i didnt tighten the lower RAd hose all the way. i fixed this before i made this post
2) The fan does work and come on when it should. I knew this before the post also.
3) The thermostat is fine
4) When i warm up the car and feel both radiator hoses, they are hot.
5) The head gasket is fine.
6) I am going to rule it as bleeding the coolant system. I bled it once already but hey, cant hurt to bleed it again.
EDIT: --FOLLOW UP--
Well i bled the coolant system and a few more bubbles came out so that is what it was.
My advice to anyone that had this problem...... Fill, bleed, fill, bleed.
Bleed it from the "coolant bleed nipple" on the engine block.
Old Nov 3, 2004 | 12:29 PM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spcrxracer &raquo;</TD></TR><TR><TD CLASS="quote"> I bled it ; bleed it again.
EDIT: --FOLLOW UP--
Well i bled the coolant system ; Fill, bleed, fill, bleed. </TD></TR></TABLE>
good advice
Old Jul 30, 2006 | 05:51 AM
zccr-xsi's Avatar
u sure your clip for the temp sending unit it good and tight.i had the same prob and when i checked that clip it was lose as ****.it made my temp go up and down and a split second.worth a look.
Old Jul 30, 2006 | 10:00 AM
Jonknee's Avatar
Default Re: (vteckillenzc)
Yeah i dont think the fan would have caused it to overhead from 10 min of driving, ive been driving for 3 months half hour a day with no fan.
Old Jul 30, 2006 | 10:51 AM
SETI20's Avatar
Yup...air is the most common thing causing bad readings. Looks like you got it fixed. Good job.
Shalka
Classic Hondas
11
Feb 12, 2015 12:16 PM
varadinn
Mar 2, 2010 02:25 PM
jeezyskillz
Nov 21, 2006 11:41 PM
tmihok
Nov 8, 2005 03:15 PM
Mr Boston
Jun 8, 2003 04:59 PM
