No fuel?
Ok, this weekend me and a couple friends put my b16 into my eg. It's got spark, and it's getting air, i primed it a few times but when I pulled the spark plugs out I could smell no fuel on them. We sprayed starter fluid into the intake mani and it tried to start up, but we can't figure out why it's not getting fuel. All the lines are connected correctly.The motor was sitting for about a year and i've heard that the air could have seized the injectors. Anybody know anything about that or have any suggestions?
-If I come across anything else i'll just edit this thread. Thanks h-t
Yep the injectors can sease up closed. I installed a junk yard engine into a 85 crx si and the injectors were toast. He left with his original injectors and some other stuff. Junk yard guys steam clean fuel injected engines, that is bad. hope you get it runnin soon
I can hear the pump priming when I turn on the car, and when i tried it w/o the line connected fuel squirted to the ground so i know the pump has got to work.
b16a1eg6
26
Feb 19, 2011 02:42 PM
