Woohoo! Did someone say lubrication ??? oil thread ...
Thoughts on this "treatment" > ? I found it looking for a gun lubricant.
http://www.militec-1.com/
Specs:
http://www.militec-1.com/specs1.html
Compare with ones like:
[Mobil 1]
http://www.mobil.com/USA-Engli...0.asp
[Castrol Syntec]
http://www.castrol.com/liveass...a.pdf
Specs:
[Mobil 1]
[Castrol Syntec]
oil is surely not my concentration of knowledge, but im sure dotRJ the "oil Guru" will have a sufficient response
Sounds kinda like all the other slick50 type zMax type stuff out there, doesn't it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
When MILITEC-1 is applied to a metal surface, it chemically reacts with, and is adsorbed by, the metal. The chemical reaction takes place at temperatures between 100°F and 150°F (38°C - 66°C) depending on friction and load conditions. The effect of the chemical reaction is a stiffening (not hardening) of the metal surface -- approximately seventeen times stiffer when the reaction is complete. The increased stiffness dramatically reduces friction and parasitic drag, just as when an underinflated tire is pumped up.
I don't see how stiffer piston rings are going to reduce friction?
I agree on the surface (no pun) it looks like a bunch of talk without numbers, although they've got quite a few contracts with the stuff.
Comparing what specs I can, it is comperable to M1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero »</TD></TR><TR><TD CLASS="quote">Oil threads are the devil.</TD></TR></TABLE>
Oil threads in the R forum are teh suck. Go to the oildrop forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs »</TD></TR><TR><TD CLASS="quote">No offense, but I'll stick with Guntec from Liqui-Moly GmbH for my lubing up my firearms.</TD></TR></TABLE>
lol, it's a discussion, no offense necessary
...but they ARE shipping hundreds of thousands of gallons of this stuff to Iraq. Makes you wonder...
its probably good for guns, but i wouldnt use this in an engine by itself.
Viscosity @ 212F/100C cst 5.63 = 10W.
yeah I was pondering using it as an additive.
nothing super concrete though in terms of chemical makeup.
